purpose of blue identification LED
kerry.c.carter1
I am a tech writer and am writing a troubleshooting section which involves the ACS 3415. All Cisco documentation just says the Identification LEDs "illuminate when the LED is on" - ok, but what is it identifying? Is it showing the identification switch is on, and if so does that really serve any purpose during troubleshooting?  Thanks for any help!
Mark Malone
Hi heres the LED list and what they mean , they are handy for visual troubleshooting anything red usually bad no matter what Cisco device
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/installation/guide/appliance/ovrvuap.html
The following table describes the callouts in Figure 1-2.
No.
Switch or LED Indicator
Description
CD-ROM drive activity LED
On = Activity
Off = No Activity
USB Connector (not supported)
Do not use.
Front unit identification LED
Glows blue after you switch on unit ID switch.
NIC 2 link/activity LED
On = Link
Off = No Link
Blinking = Activity
NIC 1 link/activity LED
On = Link
Off = No Link
Blinking = Activity
6
System health LED
Green = Good
Amber = Degraded
Red = Critical Error
7
Video connector (not supported)
Do not use.
8
Power On/Off LED
Blinking Green = Power is connected but not on
Green = Power On
Amber = Standby Mode
Off = Power Off
9
Unit Identification Switch
When switched on, the Unit Identification LEDs on the front and back panels glow blue.
Floppy drive activity LED
On = Activity
Off = No Activity
Thank you so much! This is exactly what I was looking for! I looked everywhere for something like this but couldn’t find it myself. Appreciate the prompt reply.
