QoS policy for Nortel phones
jeff_turl
We use Nortel IP phones (1140E), according to the Nortel documentation Voice media is tagged by the phones as DSCP 46 and Signalling as DSCP 40.
Can someone tell me where i have gone wrong! On my switch (3750) i trust the DSCP and have the cos-dscp map set
The router (2621XM) i have the COS-DSCP set, and a service policy.  However when i view the service policy (atm0/0.1) i don't see anything tagged as DSCP 46 only 48:
Switch:
mls qos map cos-dscp 0 8 16 24 32 40 46 56
mls qos
interface r FastEthernet1/0/1 - 48
switchport access vlan 100
switchport mode access
switchport voice vlan 300
priority-queue out
mls qos trust dscp
spanning-tree portfast
Router:
class-map match-any Voice-Media
match ip dscp ef
match ip dscp cs6
class-map match-any Voice-Signalling
match ip dscp cs5
policy-map Torbay_VOIP
class Voice-Media
  priority percent 20
class Voice-Signalling
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
interface ATM0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0.1 point-to-point
description BT Baseband PREM to Pgn Library
ip address 172.25.200.234 255.255.255.252
cdp enable
pvc 0/32
  vbr-nrt 4378 4378 1
  encapsulation aal5snap
  service-policy output Torbay_VOIP
#sh policy-map interface atm 0/0.1
ATM0/0.1: VC 0/32 -
  Service-policy output: Torbay_VOIP
    Class-map: Voice-Media (match-any)
      80 packets, 14229 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: ip dscp cs6 (48)
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Output Queue: Conversation 136
        Bandwidth 20 (%)
        Bandwidth 875 (kbps) Burst 21875 (Bytes)
        (pkts matched/bytes matched) 80/14229
        (total drops/bytes drops) 0/0
    Class-map: Voice-Signalling (match-any)
      9 packets, 450 bytes
      Match: ip dscp cs5 (40)
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 137
        Bandwidth 5 (%)
        Bandwidth 218 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 1/50
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: class-default (match-any)
      5735 packets, 3604650 bytes
      5 minute offered rate 234000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 128
        (total queued/total drops/no-buffer drops) 0/0/0
         exponential weight: 9
Jeff,
I take it that you only have the ONE sub interface.
Then the band statement should be applied to both
int atm 0/0
band 4096
int atm 0/0.1
band 4096
The other thing I wanted to mention was the amount of EF9 (SPEECH) bandwidth is codec related
Approx 80K per G711 call
Approx 25K per G729 call
Make sure your % priority statement give you enough for the number of simultaneous calls you want
E.G.
20 calls using G729 = app 500K
If you reserve only 20% of a 1M link then you would over subscribe and probably have poor quality complaints when too many calls are made
IE you would need 50% reservation
Alex
please rate useful posts
Regards, Alex. Please rate useful posts.
15 Replies 15
acampbell
Jeff,
Can you post the config of the 3750 port which connects the router.
Also is this a BCM or Meridian CS1000
Alex
the Phone system is a CS1000.
Here is the config from the switch:
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Bishops-Place-Switch1
boot-start-marker
boot-end-marker
enable secret 5 xxxx
username ciscoadmin password 7 xxxx
aaa new-model
aaa authentication login default group radius local
aaa authentication login console none
aaa authentication enable default group radius enable
aaa session-id common
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
switch 1 provision ws-c3750-24p
system mtu routing 1500
ip routing
ip domain-name torbay.local
ip name-server 172.22.200.22
ip name-server 172.22.200.6
mls qos
crypto pki trustpoint TP-self-signed-1164516992
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1164516992
revocation-check none
rsakeypair TP-self-signed-1164516992
power inline consumption default 10500
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
lldp run
interface range FastEthernet1/0/1 - 24
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/0/1
description Trunk to Router
switchport trunk encapsulation isl
switchport mode trunk
speed 100
duplex full
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/0/2
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 172.23.146.1 255.255.255.0
interface Vlan300
ip address 172.18.146.1 255.255.255.0
ip classless
ip route 172.22.0.0 255.255.0.0 172.23.146.254
ip route 172.25.0.0 255.255.0.0 172.18.146.254
ip route 0.0.0.0 0.0.0.0 172.23.146.254
ip http server
ip http access-class 11
ip http secure-server
ip sla enable reaction-alerts
logging 172.22.200.254
access-list 11 remark Restrict HTTP access to Networks
access-list 11 permit 172.22.200.254 log
access-list 11 permit 172.22.100.0 0.0.0.31 log
access-list 11 permit 172.23.146.0 0.0.0.3 log
access-list 11 deny   any log
snmp-server community plentyaft3r RO 11
snmp-server enable traps snmp authentication
snmp-server enable traps config
radius-server host 172.22.200.87 auth-port 1645 acct-port 1646 key 7 xxxx
banner motd ^C Bishops Place Switch1 ^C
line con 0
line vty 0 4
access-class 11 in
exec-timeout 0 0
password 7 xxxx
line vty 5 15
access-class 11 in
exec-timeout 0 0
password 7 xxxx
ntp clock-period 36028832
ntp server 172.22.200.22
end
Jeff,
Can you issue a couple commands on your 3750
Bishops-Place-Switch1# clear mls qos int stat
Wait about 10 mins and make your that some IPT calls have been placed over the WAN
then post the ouput of
show mls qos int g1/0/1 stat
Alex
Alex, thanks for your responce.
Here is the output from one of the access ports:
FastEthernet1/0/23
trust state: trust dscp
trust mode: trust dscp
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
Here is the output from the trunk port:
COS override: dis
default COS: 0
Trust device: none
show mls qos int g1/0/1 stat:
dscp: incoming
  0 -  4 :         280            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :          24            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :         141            0            0            0            0
45 - 49 :           0            0            0           96            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :         301            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :          24            0            0            0            0
  5 -  7 :         141           96            0
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:         141           0           0
queue 1:          40           3        1778
queue 2:           0           0           0
queue 3:           0           0           0
  output queues dropped:
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Jeff,
The issue you see is due to the cos-dscp map
The packets leave the swith towards the router as COS 6 DSCP CS6 (48)
This is usually used for network control data like HSRP etc.
Throught the WAN you really want your EF traffic to pass outbound as DSCP EF (46)
By default Nortel use DSCP CS5 (40) for signalling
We want to see this in the loose AF3 Q.
On your 3750 can you try making the follwing changes :-
mls qos map cos-dscp 0 8 16 40 32 46 48 56
On you router change
match ip dscp ef
no match ip dscp cs6
Give this a try and retest.
Alex
Alex, thanks for your help, i see traffic leaving the router atm int makred as dscp ef 46 now!!
Do i need to do anything for the signalling or does that qos map sort that out as well?
The QoS map i used previously had come from Nortel!  Thanks for the useful commands i think i will have to check the rest of my other switches out now!
Bishops-Place-Router1#sh policy-map int atm 0/0.1
ATM0/0.1: VC 0/32 -
      8133 packets, 586568 bytes
      5 minute offered rate 28000 bps, drop rate 0 bps
        5 minute rate 28000 bps
      Queueing
        Strict Priority
        Bandwidth 20 (%)
        (pkts matched/bytes matched) 110/7920
      425 packets, 22481 bytes
        5 minute rate 0 bps
      Queueing
        Bandwidth 5 (%)
        (pkts matched/bytes matched) 0/0
      14184 packets, 3944802 bytes
      5 minute offered rate 72000 bps, drop rate 0 bps
      Match: any
      Queueing
  class    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
           pkts/bytes       pkts/bytes       pkts/bytes    thresh  thresh  prob
      0   13738/3877650         0/0              0/0           20      40  1/10
      1       0/0               0/0              0/0           22      40  1/10
      2       0/0               0/0              0/0           24      40  1/10
      3       0/0               0/0              0/0           26      40  1/10
      4       0/0               0/0              0/0           28      40  1/10
      5       0/0               0/0              0/0           30      40  1/10
      6     452/67863           0/0              0/0           32      40  1/10
      7       0/0               0/0              0/0           34      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
Jeff,
I think I read the same doc re the Nortel phones to cisco switches.
My opinion is that they have made a mistake in the doc.
They get you to ammenf the COS-DSP map so to me they should then have use
mls qos trust COS on the phone ports
They have used trust DSCP in the doc.
If you are using a BT WAN like IP-Clear etc you need to send your your traffic as
RTP-Media in EF
SIGNALLING in AF3
Make sure that you ask the WAN provider to put QOS throughout your WAN.If you dont your traffic will be passed through their network as BEST EFFORT even though you are trying to prioitise at your ends.
Alex
please rate useful posts.
I know the document you mean, i think i will be doing some shreadding later on!!!
All our sites are back-to-back router configs, so we control the CO and CPE and just rent copper/fibre Point to Point circuits.
Please excuse my ignorance, but this is my first attempt at implementing QoS, the switches seems simple enough as these i will jsut trust the DSCP.
On the routers, do i need to do anything else for media or signalling?  i assume the EF uses the priority egress queue, but i wasnt sure that my output policy was correct, as i have signalling as CS5, and i wasn't sure how much bandwidth to guarentee the phones, i have used 20% and 5% (line rate is 4608, vbr is set to 95% 4378):
match ip dscp ef
match ip dscp cs6
match ip dscp cs5
class Voice-Media
  priority percent 20
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
Jeff,
For the media leve out the CS6 this is network control packets
match ip dscp ef
On your router interfaces make sure you configure the correct bandwidth
int atm 0/XXXX
band 2000 (for 2M)
The QOS statements you are using are percentages % of this bandwidth
If you dont configure you will be using the Cisco defaults like 1.544M on a serial.
So that may be useless for your setup.
As for the amount of bandwidth for signalling allocating 5% sounds reasonable.
I am not sure what the actual amount is for Nortel but it is 265bps per phone or channel on cisco IPT
So 10 phones and 6 isdn channels registered over the WAN to CUCM  would be 16 x 265 = 4.24Kbps
Alex
Thanks Alex, sorry i had already done your recommendation of: no match ip dscp cs6
i was just looking at an old copy of the config!
the interface is a a G.SHDSL (WIC-1SHDSL v2) and is configured as follows, do i need to apply the bandwidth to the controller/ATM or ATM sub interface?
controller DSL 0/0
mode atm
line-term cpe
line-mode 4-wire enhanced
dsl-mode shdsl symmetric annex B
line-rate 4608
interface ATM0/0
no ip address
cdp enable
pvc 0/32
  vbr-nrt 4378 4378 1
Thanks for the info about nortel phones 256bps is not much for signalling, is the signalling the comms from the handset back to the CS1K servers?
Jeff
Jeff,
If you are using ADSL use the upstream speed IE the low one
for SDSL then use the bandwidth you have odered like 4M = 4096
Signalling should not be much but you do want it to be given some guarantee hence it is ahead of the default traffic in the policy map.
You do not want signalling packet to be delayed etc or faults like delay to dial tone or phones not answerring when the handset is lifted etc etc
Signalling is phone set to sig server for packets like off hook, dialled digits, hold pressed etc etc
Alex
Alex, thanks.  As i use point to point sub interfaces, does the bandwidth command go on the ATM 0/0 or ATM 0/0.1.
Each ATM interface has a just single sub interface.
Jeff
Jeff,
int atm 0/0
band 4096
int atm 0/0.1
band 4096
E.G.
Alex
