QSIG MGCP to H323
martin01
this is the situation.
MGCP:
1 PRI DMS-100 to PSTN
1 PRI QSIG to PBX (for internal call 1-7 xxx)
When I change the MGCP to H323.
PRI over PSTN, works fine
PRI for the PBX, doesn't works.
If I call from Cisco, no problem except the hangup (doesn't work). If I call from the PBX, sometime work with a delay (2-3 secondes).
I attach the config MGCP and H323.
Can you help me??
Thanks!
Martin
aalejo
Level 5
Level 5
Does not work means?
1.- Both PRI Layer 1 are down?
2.- Both Pri layer 2 are down?
3.- Layer 1 and 2 are up but no calls go through?
2 PRI are up (lawer 1 and 2)
The PRI for the PSTN, I can make and receive many call, no problem with this part.
For the PRI to the PBX... I attach the debug
You have a call loop.....
Thanks. Other question...
I have extension 3xxx on my CCM and my PBX have 3xxx, 1-7xxx over PRI 0/0/1 and PSTN (for external call) on my PRI 0/0/0. I have difficult with my dial-peer. This is my last try. When I call from the PBX and PSTN I receive the dial tone.
dial-peer voice 4000 voip
destination-pattern ....
session target ipv4:172.27.2.10
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 1 pots
destination-pattern [4-5].........
direct-inward-dial
port 0/0/0:23
forward-digits 10
dial-peer voice 2 pots
destination-pattern 1[2-8].........
direct-inward-dial
port 0/0/0:23
forward-digits 11
dial-peer voice 3 pots
destination-pattern 011T
direct-inward-dial
port 0/0/0:23
forward-digits 12
dial-peer voice 4 pots
destination-pattern [1-7]...
direct-inward-dial
port 0/0/1:23
forward-digits 4
Thanks!
Martin
