04-06-2011 11:15 PM - edited 03-16-2019 04:23 AM
Hi Team,
My customer requirement to configure Polycom® SoundStation® IP 7000 Phone with CME 8.5. I tried searching the compatibility matrix in Ploycom site and as other but no Luck. I found Call manager will support IP 7000 phone registration as SIP end point.
Can you please let me if the Polycom IP 7000 phone registration supported by CME. Also please guide me how to configure.
Appreciate your quick response.
Reagrds,
Nirmal
Solved! Go to Solution.
04-08-2011 07:43 AM
While the interop may not be offically supported, you should still be able to get the phone operational with CME via SIP.
Consult the CME SIP Implementation Guide for config guidelines:
Be sure to rate helpful posts!
-Logan
04-08-2011 12:09 AM
Hi Team,
Appreciate your help in this regards.
04-08-2011 07:43 AM
-Logan
03-31-2012 05:49 AM
Hi Nirmal,
Did the integration of IP 7000 CME 8.5 work for you finally?
I am currently working on integrating Polycom IP 7000 with CME 8.6 and facing some issues. I would like to know if this integration actually works.
I have appended my CME config and error messages at https://supportforums.cisco.com/message/3600779#3600779. Could you please help here?
Suchitra
