Question: How do I add config files for the Cisco 6921 phones to my Call Manager Express??
Mike Shoop
                   My Call Manager Express only has Config files for the 79XX series of telepbones. How can I get the necessary files to be able to use Cisco 6921?
Also, since I don't already have the files in my system, will I have to purchase these from Cisco?
Jaime Valencia
Whats your CME version?
java
if this helps, please rate
Thanks for your response Jaime, the version is 12.4.
thanks again.
You need to upgrade to a version which supports 6921s
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
java
www.cisco.com/go/pdihelpdesk
java
