"auto qos voip cisco-phone" command not working on switch
Tracy La Rue
Hi All,
Have a 4510 switch that I found 2 ints not configured in our standard format like most all of the other ints on the switch.
When I tried to configure them with our standard config got the error message below after the "auto qos voip cisco-phone" command:
NRI-USTXWDL01-SW4510(config-if)# auto qos voip cisco-phone
AutoQoS Error: the following generated command was not properly applied:
service-policy input AutoQos-VoIP-Input-Cos-Policy
AutoQoS Error while generating commands on Gi8/9.
What does this mean? All of the other ints were configured with this command when switch was first configured last September.
Here's an example of one:
interface GigabitEthernet1/7
 switchport access vlan 30
 switchport mode access
 switchport voice vlan 20
 switchport port-security maximum 3
 switchport port-security aging time 2
 switchport port-security violation restrict
 switchport port-security aging type inactivity
 qos trust device cisco-phone
 spanning-tree portfast
 spanning-tree bpduguard enable
 service-policy input AutoQos-4.0-Cisco-Phone-Input-Policy
 service-policy output AutoQos-4.0-Output-Policy
Thanks for your help.
Tracy
Terry Cheema
Tracy,
Whats the IOS version on the switch? Was it recently upgraded?
Can you share the interface configuration that gives this error? Is the error you have pasted complete or does it give any further output for any reason etc. why it is unable to apply the auto qos?
Can you also try to default the interface: "default int GX/Y"
Copy all the config to a notepad prior to that and paste the config back, first apply just the base config vlan etc. and try to apply auto qos config and see how yo go.
-Terry
Please rate all helpful posts.
5 Replies 5
Terry Cheema
Tracy,
-Terry
Hi Terry,
I just didn't think it would work but I gave it a go anyway.
I defaulted the ints again and added in this order:
And it worked! No error message.
NRI-USTXWDL01-SW4510-A1A#config t
Enter configuration commands, one per line.  End with CNTL/Z.
NRI-USTXWDL01-SW4510(config)#interface GigabitEthernet8/9
NRI-USTXWDL01-SW4510(config-if)#switchport access vlan 30
NRI-USTXWDL01-SW4510(config-if)# switchport mode access
NRI-USTXWDL01-SW4510(config-if)# switchport voice vlan 20
NRI-USTXWDL01-SW4510(config-if)#auto qos voip cisco-phone
NRI-USTXWDL01-SW4510(config-if)# switchport port-security maximum 3
NRI-USTXWDL01-SW4510(config-if)# switchport port-security aging time 2
NRI-USTXWDL01-SW4510(config-if)# switchport port-security violation restrict
NRI-USTXWDL01-SW4510(config-if)# switchport port-security aging type inactivity
NRI-USTXWDL01-SW4510(config-if)# spanning-tree portfast
Thanks Terry!
Not a prob Tracy, glad that helped! From experience when switch ports are not behaving as they should for no apparent reason - defaulting and reconfiguring solves the issue most of times :)
Anyways good to see your issue is resolved.
See you around.
-Terry
Hi Tracy La Rue,
 if you recently upgrade your switch, then you should remove all the 'auto qos' commands and insert it again.
Hope this helps.
Hi Marcelo,
Thanks for your reply to my post. The issue was resolved thru Terry's post.
