08-18-2011 07:33 PM - edited 03-16-2019 06:34 AM
Log Buffer (4096 bytes):
egistered with Gatekeeper VoGK27KI-SKO_Shilong
.Apr 28 2011 13:33:06.077 CHT: %SYS-5-CONFIG_I: Configured from console by vty0 (172.31.1.2)
.Apr 29 2011 02:52:10.112 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK27KI-SKO_Shilong
.Apr 29 2011 02:52:10.192 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK26AI-SKO_Shilong
.May 12 2011 21:32:42.725 CHT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
.May 12 2011 21:32:48.725 CHT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.73.18.10 port 514 started - reconnection
.May 12 2011 21:32:53.726 CHT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.11.9.70 port 514 started - reconnection
.May 12 2011 22:17:49.358 CHT: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
.May 12 2011 22:17:55.358 CHT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.73.18.10 port 514 started - reconnection
.May 12 2011 22:18:00.358 CHT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.11.9.70 port 514 started - reconnection
.May 16 2011 00:03:43.561 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK26AI-SKO_Shilong
.May 16 2011 00:03:58.562 CHT: %CCH323-2-GTWY_REGSTR_FAILED: Gateway SKO failed to register with Gatekeeper VoGK27KI-SKO_Shilong even after 2 retries
.May 16 2011 00:04:09.718 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK27KI-SKO_Shilong
.May 22 2011 00:47:27.826 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK27KI-SKO_Shilong
.May 22 2011 00:47:32.906 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK26AI-SKO_Shilong
.May 24 2011 15:38:10.726 CHT: %LINK-3-UPDOWN: Interface recEive and transMit 1/0/0, changed state to Administrative Shutdown
.May 24 2011 15:38:18.818 CHT: %LINK-3-UPDOWN: Interface recEive and transMit 1/0/0, changed state to up
.May 24 2011 15:39:02.940 CHT: %LINK-3-UPDOWN: Interface recEive and transMit 0/3/0, changed state to Administrative Shutdown
.May 24 2011 15:39:09.348 CHT: %LINK-3-UPDOWN: Interface recEive and transMit 0/3/0, changed state to up
.May 24 2011 15:39:18.392 CHT: %SYS-5-CONFIG_I: Configured from console by console
.May 24 2011 15:47:49.162 CHT: %LINK-3-UPDOWN: Interface recEive and transMit 1/1/0, changed state to Administrative Shutdown
.May 24 2011 15:47:58.854 CHT: %LINK-3-UPDOWN: Interface recEive and transMit 1/1/0, changed state to up
.May 24 2011 15:48:35.411 CHT: %SYS-5-CONFIG_I: Configured from console by console
May 27 2011 04:02:09.911 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK26AI-SKO_Shilong
May 27 2011 04:02:24.911 CHT: %CCH323-2-GTWY_REGSTR_FAILED: Gateway SKO failed to register with Gatekeeper VoGK27KI-SKO_Shilong even after 2 retries
May 27 2011 04:04:43.123 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK26AI-SKO_Shilong
Jun 6 2011 12:55:56.070 CHT: %SYS-5-CONFIG_I: Configured from console by vty0 (172.31.1.2)
Jun 14 2011 03:25:04.358 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK26AI-SKO_Shilong
Jun 14 2011 03:25:09.454 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK27KI-SKO_Shilong
Jun 15 2011 01:55:05.228 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK27KI-SKO_Shilong
Jun 15 2011 01:55:05.332 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK26AI-SKO_Shilong
Jun 22 2011 14:44:13.224 CHT: flex_dsprm_vtsp_open - ACTIVE CALL
Jun 30 2011 04:21:25.795 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed attempt to register with Alternate Gatekeeper VoGK26AI-SKO_Shilong
Jun 30 2011 04:21:25.891 CHT: %CCH323-6-REGSTR: Gateway SKO registered with Gatekeeper VoGK27KI-SKO_Shilong
Jul 7 2011 14:40:53.984 CHT: %SYS-5-CONFIG_I: Configured from console by vty0 (172.31.1.2)
08-25-2011 07:41 PM
Hi Suguo,
The GW will register to the redundant GK when the primary GK registration fails. And it will only register back to the primary if it loses connectivity to the alternate.
The output you saw seemed casued by either a flapping of the internface or network connectivity issue.
I hope this helps.
Amy Lin
