ā01-28-2010 06:22 PM - edited ā03-15-2019 09:14 PM
I have a Cisco Call Manager 7.1.3 and Cisco Unity Connect Environment
I am requesting your assistance with implementing the following call forwarding option:
Scenario
Phone 1 DN= 5054, VM enabled
Phone 2 DN = 5160 VM enabled.
I would like internal calls forward no answer be routed to DN 5160 and then if no answer DN 5160 VM
To achieve this I configured the fbelow call forward options"
Phone 1
Call Forward no answer DN 5160
Phone 2
Call Forward no answer VM checked
Howevrer this is the result
Calls when received on DN 5054 are forwarded to 5160 however the voicemail received is 5054.
How can I configure this so that when the call is forwarded to 5160 and there is no answer the VM received is for 5160?
MLaing
ā01-28-2010 06:53 PM
This has been asked PLENTY of times before, please search NetPro for answers
Cisco Unity Connection Administration
Advanced (towards the bottom of the page)
Conversation Configuration
Use Last (Rather than First) Redirecting Number for Routing Incoming Call
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā02-04-2010 10:57 AM
This resolves the issue, how do I rate this?
Marsha Laing
Networking Sales Specialist
IBM World Trade Corporation (Jamaica)
52-56 Knutsford Boulevard
Kingston 5
Phone: (876) 9263179
Direct: (876) 9354129
Fax: (876) 926-3225
Email: mlaing@jm.ibm.com
javalenc
To:
Marsha Laing/Jamaica/IBM@IBMCA
Date:
01/28/2010 09:54 PM
Subject:
New message: "Re: Cisco call Manager 7.1.3 Call Forwarding
m-laing,
A new message was posted in the Discussion thread "Re: Cisco call Manager
7.1.3 Call Forwarding Options":
https://supportforums.cisco.com/message/3010135#3010135
Author : javalenc
Email : javalenc@cisco.com
Profile : https://supportforums.cisco.com/people/javalenc
Message:
ā02-04-2010 01:39 PM
Click on the link for the post and log with your credentials (opposed to replying via email), you'll see 5 stars below any reply which you use to rate. Just click on the number of stars you wish to rate.
java
If this helps, please rate
