Recommendation on CM 10.5.2 upgrade to 10.5.2.14900-16
glenn.newman
This upgrade came out on Nov 1st and is supposed to fix bug CSCuu78454. The bug says that it will cause a memory leak.  So far we have not seen increased memory use on our systems.
Has anyone seen any issues with this latest version or with memory leaks on 10.5.2.13901-2?
Chris Deren
It is a good idea to upgrade to latest available SU to resolve caveats that were fixed in the release. Looking at the readme for CUCM in this version there are quite a few listed, see page 5:
http://www.cisco.com/web/software/282074295/135651/cucm-readme-1052su4-Rev2.pdf
The bug you references is one of the resolved ones.
