02-08-2018 05:04 AM - edited 03-17-2019 12:09 PM
Can anyone suggest a router for MTP, I currently have IPVMS running on 2 nodes in our cluster but we are running out of resource which is causing intermittent DTMF issues.
Cheers
02-08-2018 07:11 AM
You need to mention the number of sessions you need, the codec, and if they're going to be HW or SW in order to get an answer.
02-08-2018 07:34 AM - edited 02-08-2018 07:35 AM
Excuse my brevity, concurrent SIP sessions is around 200, codec G711 and looking to do SW based if possible.
I was looking at spinning up additional subscribers and have those running IPVMS and no call processing as I know its bad practice to have IPVMS and Call processing running on the same pub/sub.
Let me know your thoughts.
RD
02-08-2018 08:03 AM
02-08-2018 08:10 AM
Hi Nipun,
We are using oracle 3820 session boarder controller cluster as gateway, which I dont believe can provide software MTP resource(s) (someone correct me if I'm wrong)
Hence why I'm looking at deploying either router or additional node(s) into the cluster to handle MTP resource allocation. I'd prefer to use a router to provide software based MTP resource to be perfectly honest.
02-08-2018 08:15 AM
02-08-2018 08:17 AM
See table 9
On older platforms you'd need at least a 2821 or a 2911 to get 220 SW MTP sessions as a dedicated MTP resource. Any platform above those, provides above 220 SW MTP sessions. These old models are already phasing out from support.
02-08-2018 08:44 AM
Hi Jamie,
With the 4321, what IOS license would you need to provide the MSP functionality?
02-08-2018 08:48 AM
UC license, you'll need to reach a Cisco Partner to buy this, and they will help you with ordering the right BOM for this.
