regarding these phones 7965G and 7911G Firmware upgrade
dmsherazi
Hi, I need some technical support regarding  these phones 7965G and 7911G . I want to change the firmware to SIP using TFTPD32 software.
I made a factory default by pressing # key while powering up, and then pressed 123456789*0# when the lights stated blinking .
I had setup tftp server with the required files. a DHCP server with option 150  that passes the PCs (TFTP server's) IP address. THe phone gets an ip address but always keeps requesting for some wiered address
Below are the shots of some screen and  settings that explain my setup
1. Am using a PoE switch to connect the PC and Phone.
2. PC settings are as in the pic
https://www.dropbox.com/s/x9hhtlyob7sr1ci/Photo%20Jan%2029%2C%209%2020%2025%20AM.jpg
3 set up dhcp server and tftp server as follows
https://www.dropbox.com/s/zwrfb5dcnsac8jv/Photo%20Jan%2029%2C%209%2019%2051%20AM.jpg?m
https://www.dropbox.com/s/ureii3ht974xo92/Photo%20Jan%2029%2C%209%2020%2005%20AM.jpg?m
4 the phone gets an ip by the DHCP
https://www.dropbox.com/s/pzc34vdxk1tfhb9/Photo%20Jan%2029%2C%209%2019%2033%20AM.jpg?m
but the file transfers doesn't start and i see these weird logs
https://www.dropbox.com/s/sn5fq3bochlesfo/Photo%20Jan%2029%2C%209%2018%2050%20AM.jpg?m
I had tested the tFTP server by getting a file using windows tftp client by CMD and its working .
Please help me in that how can i get this done
dmsherazi
I had also done the 3491672850*# sequence  but no success
Really disappointed by no replies at alll...
any how I managed to configure them . I had to use DHCP option 66 to feed the ip address of my TFTP server.
