07-24-2015 12:13 PM - edited 03-17-2019 03:45 AM
HELP PLEASE
We are trying to Register the New “Cisco IP Phones CP-8945” But We are having some trouble with it. in a CME Version 9.1
We got about 150 new Phones and for the looks of it all the ones I´ve get out of the box the --> """Initial App Load ID" From the new Phones is that they come with Initial App Load ID SIP and not Skinny
Version: SIP 9-4-2-8
I Imagine we need to Convert the Phone Firmware App Load ID From SIP To SCCP to get the new phones working. (Any Ideas on how to get this done with the CME)
From Version: SIP 9-4-2-8 To Version: SCCP 9-4-2-8
NOTE: With a Phone that initial App Load Version: SCCP 9-4-2-8 It registers in CME witou any issues.
ADDITIONAL NOTES:
The CME is using only SCCP ((And not SIP))
+ The Guys that set it up for trying to register the phone, Uploaded the Firmware 9-2-2-0 Following the Matrix The Table:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme91spc.html
QUESTION:
Is the Version 9-4-2-8 Compatible in CME 9.1?
http://www.cisco.com/web/software/282074289/115764/cmterm-894x-sccp.9-4-2-8-readme.html
States the following:
9.4(2) can be upgraded only from SCCP/SIP 9.3(4) onwards!!!
A Downgrade Should Meet the Same Condition?????
ALSO
Table 1: Cisco IP Phone Models 8941/8945 Firmware Load
Cisco IP Phone Model | CallManager Version | Supported Protocol | Executable on Software Page | MD5 hash |
8941, 8945 | 7.1.5 and higher | SCCP | cmterm-894x-sccp.9-4-2-8.cop.sgn | 4a5c328afa41cfa4b707d538648abeed
Is the Version 9-4-2-8 Compatible in CME 9.1? IT MEETS THE CONDITION FOR CME= ???
The Phone, I see it gets an IP Address and from the
Console Logs
TID: 0x2d task name: PROVISION tag name: versionStamp value : {8945 Jul 23 2015 15:11:28}
is error format.
save_phoneServices(): input data can't find save_srstinfo(): input data can't find tftp_download_file, 180
00:01:48:21.786 - E/(SCCP894x.9-2-2-0.loads) img : download SCCP894x.9-2-2-0.loads fail ()
16:02:22, 07/18/2014 : (SCCP894x.9-2-2-0.loads) img : download SCCP894x.9-2-2-0.loads fail(2)
07-24-2015 12:20 PM
Full Conzole Logs
is error format.
download_file 1623: TFTP server=10.116.80.10 filename=CTLSEP6899CDA15E19.tlv
Error code 1: No such file
File transfer error.
TFTP error : download CTLSEP6899CDA15E19.tlv fail16:02:18, 07/18/2014 : TFTP error : down
16:02:18, 07/18/2014 : CTLSEP6899CDA15E19.tlv not found in 10.116.80.10
CTLSEP6899CDA15E19.tlv not found in 10.116.80.1016:02:18, 07/18/2014 : ITLSEP6899CDA15E19
tlv updating
provision_download_file 1596: HTTP server=10.116.80.10 filename=ITLSEP6899CDA15E19.tlv
HTTP download error, try tftp download
provision_download_file 1623: TFTP server=10.116.80.10 filename=ITLSEP6899CDA15E19.tlv
TFTP error : download ITLSEP6899CDA15E19.tlv fail16:02:18, 07/18/2014 : TFTP error : down
ITLSEP6899CDA15E19.tlv not found in 10.116.80.1016:02:18, 07/18/2014 : ITLSEP6899CDA15E19
16:02:18, 07/18/2014 : ITLFile.tlv updating
provision_download_file 1596: HTTP server=10.116.80.10 filename=ITLFile.tlv
provision_download_file 1623: TFTP server=10.116.80.10 filename=ITLFile.tlv
TFTP error : download ITLFile.tlv fail16:02:18, 07/18/2014 : TFTP error : download ITLFil
.tlv fail
16:02:18, 07/18/2014 : ITLFile.tlv not found in 10.116.80.10
ITLFile.tlv not found in 10.116.80.1016:02:18, 07/18/2014 : can't download ITLFile.tlv fr
m 10.116.80.10
download_trust_list_process : can't download ITLFile.tlv from 10.116.80.10
16:02:18, 07/18/2014 : CTL and ITL installed
provision_download_file 1596: HTTP server=10.116.80.10 filename=SEP6899CDA15E19.cnf.xml
provision_download_file 1623: TFTP server=10.116.80.10 filename=SEP6899CDA15E19.cnf.xml
provision_download_file 1628: TFTP download success
16:02:19, 07/18/2014 : SEP6899CDA15E19.cnf.xml (TFTP)
save_sepmac 2280: file write OK. write len = 1474
is error format.
(2)
*** cfgmgr_loads_task 738 callback return ***
Need to download locale resources. (Spanish_Spain, , 10.116.80.10/getfontfail, getfontfai
, 10.116.80.10)
Download Spanish_Spain/gb-sccp-sip.jar ...
file write error.
tftp_download_file, 163-len=0
Downloading Spanish_Spain/gb-sccp-sip.jar fails.
Notify application locale had changed.
download_configuration_process : exit, ret=1
LOCAL:Spanish_Spain DOWNLOAD:getfontfail from:locale_update
[MMI]Not update call ui on unregister
[springboard] _send_file()@5089: Get /CFG/phoneServices.xml Fail
into subhandler_applications:provision_ready
16:02:25, 07/18/2014 : VPN Error: VPN is not Configured.
00:01:48:25.142 - E/Checking Config: fullConfig=1
00:01:48:25.142 - E/Checking Protocol: Device=SIP. Config=SIP (OK)
00:01:48:25.143 - E/Checking SwPort: 1000-full (OK)
00:01:48:25.143 - E/Checking Network: IPV4=10.116.14.23 IPV6= (OK)
00:01:48:25.143 - E/Checking Security: NonSecure Mode (LSC: Not Installed, MIC: Installed
(OK)
00:01:48:25.145 - E/Checking Account: Undefined= (Failed)
00:01:48:25.208 - E/wallpaperCtrl.useUserDefWp() fail
provision_task_delete_and_recreate(), recreate= 1
* Rate limit enabled *
16:02:55, 07/18/2014 : CTLSEP6899CDA15E19.tlv updating
provision_download_file 1596: HTTP server=10.116.80.10 filename=CTLSEP6899CDA15E19.tlv
provision_download_file 1623: TFTP server=10.116.80.10 filename=CTLSEP6899CDA15E19.tlv
TFTP error : download CTLSEP6899CDA15E19.tlv fail16:02:55, 07/18/2014 : TFTP error : down
16:02:55, 07/18/2014 : CTLSEP6899CDA15E19.tlv not found in 10.116.80.10
CTLSEP6899CDA15E19.tlv not found in 10.116.80.1016:02:55, 07/18/2014 : ITLSEP6899CDA15E19
tlv updating
TFTP error : download ITLSEP6899CDA15E19.tlv fail16:02:55, 07/18/2014 : TFTP error : down
16:02:55, 07/18/2014 : ITLSEP6899CDA15E19.tlv not found in 10.116.80.10
ITLSEP6899CDA15E19.tlv not found in 10.116.80.1016:02:55, 07/18/2014 : ITLFile.tlv updati
g
TFTP error : download ITLFile.tlv fail16:02:55, 07/18/2014 : TFTP error : download ITLFil
.tlv fail
16:02:55, 07/18/2014 : ITLFile.tlv not found in 10.116.80.10
ITLFile.tlv not found in 10.116.80.1016:02:55, 07/18/2014 : can't download ITLFile.tlv fr
m 10.116.80.10
16:02:55, 07/18/2014 : CTL and ITL installed
16:02:56, 07/18/2014 : SEP6899CDA15E19.cnf.xml (TFTP)
is error format.
00:01:48:58.788 - E/(SCCP894x.9-2-2-0.loads) img : download SCCP894x.9-2-2-0.loads fail (
16:02:59, 07/18/2014 : (SCCP894x.9-2-2-0.loads) img : download SCCP894x.9-2-2-0.loads fai
(2)
, 10.116.80.10)
file write error.
16:03:02, 07/18/2014 : VPN Error: VPN is not Configured.
00:01:49:02.139 - E/Checking Config: fullConfig=1
00:01:49:02.139 - E/Checking Protocol: Device=SIP. Config=SIP (OK)
00:01:49:02.139 - E/Checking SwPort: 1000-full (OK)
00:01:49:02.140 - E/Checking Network: IPV4=10.116.14.23 IPV6= (OK)
00:01:49:02.140 - E/Checking Security: NonSecure Mode (LSC: Not Installed, MIC: Installed
(OK)
00:01:49:02.141 - E/Checking Account: Undefined= (Failed)
00:01:49:02.204 - E/wallpaperCtrl.useUserDefWp() fail
16:03:32, 07/18/2014 : CTLSEP6899CDA15E19.tlv updating
TFTP error : download CTLSEP6899CDA15E19.tlv fail16:03:32, 07/18/2014 : TFTP error : down
16:03:32, 07/18/2014 : CTLSEP6899CDA15E19.tlv not found in 10.116.80.10
CTLSEP6899CDA15E19.tlv not found in 10.116.80.1016:03:32, 07/18/2014 : ITLSEP6899CDA15E19
tlv updating
TFTP error : download ITLSEP6899CDA15E19.tlv fail16:03:32, 07/18/2014 : TFTP error : down
16:03:32, 07/18/2014 : ITLSEP6899CDA15E19.tlv not found in 10.116.80.10
ITLSEP6899CDA15E19.tlv not found in 10.116.80.1016:03:32, 07/18/2014 : ITLFile.tlv updati
g
TFTP error : download ITLFile.tlv fail16:03:32, 07/18/2014 : TFTP error : download ITLFil
.tlv fail
16:03:32, 07/18/2014 : ITLFile.tlv not found in 10.116.80.10
ITLFile.tlv not found in 10.116.80.1016:03:32, 07/18/2014 : can't download ITLFile.tlv fr
m 10.116.80.10
16:03:32, 07/18/2014 : CTL and ITL installed
16:03:33, 07/18/2014 : SEP6899CDA15E19.cnf.xml (TFTP)
is error format.
00:01:49:35.785 - E/(SCCP894x.9-2-2-0.loads) img : download SCCP894x.9-2-2-0.loads fail (
16:03:36, 07/18/2014 : (SCCP894x.9-2-2-0.loads) img : download SCCP894x.9-2-2-0.loads fai
(2)
, 10.116.80.10)
file write error.
16:03:39, 07/18/2014 : VPN Error: VPN is not Configured.
00:01:49:39.133 - E/Checking Config: fullConfig=1
00:01:49:39.133 - E/Checking Protocol: Device=SIP. Config=SIP (OK)
00:01:49:39.134 - E/Checking SwPort: 1000-full (OK)
00:01:49:39.135 - E/Checking Network: IPV4=10.116.14.23 IPV6= (OK)
00:01:49:39.135 - E/Checking Security: NonSecure Mode (LSC: Not Installed, MIC: Installed
(OK)
00:01:49:39.136 - E/Checking Account: Undefined= (Failed)
00:01:49:39.200 - E/wallpaperCtrl.useUserDefWp() fail
12-04-2015 02:14 PM
Im having this exact same issue. Were you ever able to get it resolved?
