Registration rejected security error in cipc.
jijopaul
Hi all,
I am trying to register a cipc in a cluster But i am getting Registration rejected security error  .I tried to register the same in difrent cluster i am getting the same error. I erased CTl from cipc issue still  persist.Can any one ellaborate what all are the possible causes of  this issue.
Thanks in advance
Jijo paul
6 Replies 6
phooghen
Could you please forward the exact error message you are getting ?
Pierre.
I am getting "Registeration rejected : security error"
Stuti Desai
Are you auto registering or trying to register it manually?
If auto registering, could you please check whether the dn  range is not exhausted?
I am trying to register it manualy.
Peekaboom
Try to create device pool with call manager server, you specified in the cipc tftp settings. And change cipc device pool to new one.
101networker
Which version of call manager are you using?
Check the link below, it may help.
http://www.cisco.com/en/US/docs/voice_ip_comm/cipc/2_1/english/administration/guide/cag21ts.html#wp1045102
