06-07-2011 10:44 AM - edited 03-16-2019 05:19 AM
Just finished upgrading CUCM 8.0.2 to CUCM 8.5.1 on a new replacement MCS 7816-I5 server. This was a bridge upgrade since CUCM 8.5.1 is
no longer supported on MCS-7825-H2 server.
I registered and received a license for CM8.5-K9-UPG= upgrade.
I requested cisco licensing to rehost my current licenses to a new MAC address and I attached my old licenses to my request.
I received about eight rehosted license files. Installed all the new license files on a new server. Restored upgraded 8.5.1 database.
Deleted old license files that had an old MAC address.
The server accepted my DLU values, but the license status showing as invalid. I restarted CM service, restarted CM server, updated MAC address in under System>Server. Nothing helped.
Can anyone think of what I'm missing?
Yury
Solved! Go to Solution.
06-07-2011 11:05 AM
Open the .lic files and make sure they're all with the same MAC address to confirm they are valid.
You can also try deleting the current license file and then upload again and restart the licensing manager.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-07-2011 11:05 AM
java
06-07-2011 12:04 PM
Thanks for your help.
MAC address was correct. Removed all the licenses, added them again, restarted CM service,
the warning message is gone and the license status is uploaded.
