Remote Access Requirements for Cisco Jabber Voice
Hi everyone!
Hi have the following doubt respect to Cisco Jabber Voice.
1. If I have the BE6000 installed with CUCM, Presence&IM, ExpresswayC and ExpresswayE and my Firewall is a Checkpoint, I need the Checkpoint VPN Client installed in the smartphones of the company to register the Cisco Jabber Voice in the smartphones?
2. The minimum licensed required for Ciso Jabber voice is Enhanced?
Regards!
Steven
Ayodeji Okanlawon
You don't need to install vpn client's since you have expressway c and e. You should be deploying MRA solution, ie the vpnless jabber solution.
Please rate all useful posts
Hi  Ayodeji thanks for you answer.
The mobile devices consume any license in the Cisco Expressway for example RichMedia license?
No, it doesnt
Jaime Valencia
You can do that, or assuming you want/meet the requirements, you can configure MRA which is a VPNless option, that's provided by the Expressways
java
if this helps, please rate
