02-01-2013 12:28 AM - edited 03-16-2019 03:28 PM
We are looking to remove various versions of CUCME from our Voice Gateways around Europe and move them to a central Call Manager platform. Does anyone know how to remove the installation of CME from the Router? I've scoured the Internet trying to find the answer but all I seem to get is how to install it. As in the CME Installation we are using a mixture of 2800 to 2900 series routers and converting them to H.323 gateways. Do I even need to remove the CME installation?
Thanks in advance for any assistance provided.
Solved! Go to Solution.
02-01-2013 01:00 AM
The software is built into IOS. You can remove the associated files from flash, and you can remove the configuration. Depending on your CUCM design you might only wish to remove part of the configuration as the existing dial peers etc might be re-used in SRST mode...
Most of the configuration if you choose to remove it is in the 'telephony-service' section, and the dial peers.
If you want to get rid of the flash files you can download a copy of the CME files and use that to determine what you can get rid of.
Aaron
02-01-2013 01:00 AM
Aaron
02-01-2013 01:15 AM
first of all you need to change option 150 on the phones or dhcp. when you complete this the phones will be registered on the callmanager at HQ.
for the gateway you need to add the h323 config:
h323-gateway voip interface
h323-gateway voip bind srcaddr xx.xx.xx.xx
then add the gateway to call manager and complete the config for ,route pattern, route list, route group, partitions, and CSS.
for cme config you can remove it by
(config)# no telephony-service.
but i think you can use it as an srst config
Anas
Sent from Cisco Technical Support Android App
