rerouting on error code Cause i = 0x80FF - Interworking error; unspecified
acolmagro
Community Member
I have a problem with my operator. It has a regional crash ant I received this error code
I have BRI backup with an other operator but the call manager does not reroute the call.
I try to put the BRI in the same route group or in an another route group but in the same rout list.
*Feb 25 09:20:00.355: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x1A99
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '565552838'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0615405708'
*Feb 25 09:20:00.375: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x9A99
*Feb 25 09:20:00.423: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x9A99
*Feb 25 09:20:00.447: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x1A99
*Feb 25 09:20:00.455: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x9A99
I need help please.
Pierre
7 Replies 7
Ayodeji Okanlawon
Audrey,
We need to be sure that CUCM didnt route the call to the backup BRI. Can you send a "debug voip ccapi inout" for the failed call? What version of CUCM are you using
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Yes i am sure it does not rerout the call. When I put my BRI first in the top down route group, the call can go out.
I am in version 9.1.2.10000
AUdrey,
Can you sedn detailed CUCM traces? There is a bug in CUCM9.X where the Route List cant find any more device in the RG after trying the first device...I will see if I can get the bug details
Hi Audrey.
Try to put CUCM service parameters "Stop routing on unallocated number flag" and "Stop routing on user busy flag" to false and try an outgoing call
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
I try that but not succefully
So... in this case, as my friend Deji suggested, collect CUCM trace and please post here so we can analyze them and see what is happening.
Carlo
Here is a similar Thread...
https://supportforums.cisco.com/message/3927483#3927483
https://supportforums.cisco.com/message/4004578#4004578
Use can use the work around,..,
Remove the BR1 from the route group, reset the Route lists and re-add the BR1 back and test again
