Reset the Administrative Reporting Tool password phrase in 4.1 ccm
lawrencekjoseph
when i reinstall the ART the password phrase is not validating . how i can reset the password phase .
5 Replies 5
lawrencekjoseph
when i reinstall the ART the password phrase is not validating . How i can reset the password phase .
i had done the password rest through the admin utility But it did not help me to resetting the ART password phrase
kindly help to reslove this issue.
ok, you are talking about 2 different thing
one is the private password phrase that is used for install plugins.
the other one is the password to log into CAR
which one are you talking about??
if it's the CAR pwd just do a search on netpro, this has been addressed several times in the past
javalenc
if this helps, please rate
java
Hi i am talking about the private password phrase that is used for install plugins in the server .
how i can rest the plugin password it is not validating the password .
adminutility should do that, stop CSA, any kind of FW, antivirus, etc before running it. you can refer to the readme to see all that can prevent it from working fine
javalenc
java
The admin utility did not help to resolve the issue. I had used the admin utility .
The ART cisco plugin password phrase is not validating. How i can reset the administartive reporting tool.
