I assume you are using Cisco Unity. Typically, your ID is your internal phone number. Let's say your organization uses 4 digits to dial extension to extension, that 4-digit extension is typically your ID. If it's asking for your password, you will have to go to Cisco Unity Connection to reset the password. Ideally you will also need your extension which is the warm as your ID for the voicemail
