02-05-2017 02:39 AM - edited 03-17-2019 09:25 AM
Hi ,
We have two fxo lines . is it possible to restrict one of the line usage only among two people . and another one common for all .
we are running cucm 11.X version.
Solved! Go to Solution.
02-05-2017 07:36 AM
Yes you can do this. Depending on what protocol you are using to connect CUCM with voice gateway.
For example, if you connect to gateway using SIP trunk.
1. On your gateway create cor-lists for FXO_1 and cor-list for FXO_2
2. Create dial-peers to match calls from two people using answer-address
3. Assign cor-list FXO_1 to this dial-peer.
4. Create outgoing dial-peer out of FXO Port 1 and assign the corresponding cor-list to it.
5. Create dial-peer to match calls from rest of people and assign cor-list FXO_2 to this dial-peer
6. Create outgoing dial-peer out of FXO Port 2 and assign the corresponding cor-list to it.
Here is a document on how to create cor-lists
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
02-05-2017 07:36 AM
02-05-2017 08:50 AM
Hi Mohammed,
Thank you for replying . we have h.323 gateway .attached is the configuration done for the gateway .
fxo line on port 0/0/1 is for everyone and port 0/0/0 is only for GM and his PA.
can I follow the same configuration advised above ? could you please provide one sample configuration if possible .
02-05-2017 09:31 AM
Yes you can use the same steps as described above.
02-05-2017 09:14 PM
I have done some configuration as below , could you please suggest whether this will work .would like to know before implementing in gateway.
dial-peer cor custom
name Farook&Mohammed
name All
dial-peer cor list Farook&Mohammed
member Farook&MOhammed
dial-peer voice 937 pots
corlist outgoing Farook&Mohammed
preference 1
destination pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 938 voip
corlist incoming Farook&Mohammed
answer-address 666
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
port 0/0/0
dial-peer voice 939 voip
answer-address 660
voice-class codec 1
no vad
port 0/0/0
02-07-2017 01:53 AM
Thank you so much Mohammed. Below configuration worked well as per your suggestion.
name FarookMohammed
dial-peer cor list FarookMohammed
member FarookMohammed
dial-peer cor list All
member All
dial-peer voice 101 pots
description *** FOR INCOMING CALL MATCHING ***
direct-inward-dial
corlist incoming FarookMohammed
answer-address 660
port 0/0/0
dial-peer voice 104 pots
direct-inward-dial
answer-address 666
port 0/0/0
dial-peer voice 105 pots
tone ringback alert-no-PI
description *** O/G LEVEL 9 TRAFFIC TO PSTN ***
destination-pattern 9T
direct-inward-dial
corlist outgoing FarookMohammed
port 0/0/0
