Ring Alert on multiple lines
Nahassamad_2
Hi all,
Is there any way to ring two lines at sametime in a single call (without shared line)
Thanks in advcance
Nahas
marina.kaminski
You can configure a broadcast line group to ring multiple lines at the same time
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b03lngrp.html
Thanks for the response..
Yes you are right.I have tried this. Please see my scenario.
100 and 101 are my extension. If any calls comes to 100, both extension should ring. I have created a line group and assinged these two extension to that group with pilot 100 and the distribution algorithm is Broadcast. But i doesnt work. I think partition issue or something.
Please advice..
If you want both phones to ring when a call comes to 100, your phones should be 101 and 102 (for example). You cannot have the same number assigned to the phone line and hunt pilot. The idea behind the hunt groups is having one "real" number to recieve calls and the the CM should distribute the calls to other phones based on the algorithm you choose.
