Ringback over SIP lines (CUCMv7.1.5 --> 2811 --> SIP Provider)
gcrawford2005
Problem:
1. Ringback is not working on any phones going out my SIP gateway (2811 --> my SIP provider).
I have tried fast start for incoming/outgoing and enabled MTP, but then my DTMF stops working and I still don't have a ringback. Below are the details on my setup. If you have any input on how I should be doing things, feel free to toss it in.
2. I have a DSP in the 2811, but don't think I have anything to use it currently. How can i configure it to be used locally for whatever the 2811/SIP partner could need it for. I already have 2 MTP's configured on both CMs.
Hardware
2x CUCM v7.1.5.34900-7
1x Cisco 2811 w/ 1x PVDM2-16 & c2800nm-advipservicesk9-mz.124-22.T.bin
Cisco 2811 Config (Voice Related Parts)
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
  h225 timeout tcp establish 2
  h225 timeout call-proceeding 1
  h225 timeout setup 3
  call start fast
  telephony-service ccm-compatible
  ccm-compatible
voice-card 0
dsp services dspfarm
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer voice 1 voip
description This is for outgoing calls through the SIP...
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
session transport udp
incoming called-number 9T
dtmf-relay rtp-nte
sip-ua
credentials username **** password 7 **** realm asterisk
authentication username **** password 7 **** realm asterisk
no remote-party-id
retry invite 2
retry register 2
registrar dns:**** expires 3600
sip-server dns:****
host-registrar
10 Replies 10
Hi, could you please provide the "debug ccsip all" output? check what you receive 180(w/sdp or wo/sdp) or 183 from the provider? if you receive 180 without SDP, then make sure the MRGL assigned to the SIP Trunk has ANN to generate the ringback locally. if you receive 183 and/or 180 with SDP, then provider will generate the ringback.
//Suresh Please rate all the useful posts.
Below is the output of a call I made to an 858 number. I didn't see what you were talking about on the SDP.
As a side note, I have seen some people say they configure the Cisco 2811 as a SIP gateway rather than H323. Is there pros or cons to doing this?
I talked to our SIP provider and they recommend configuring our equipment to accept 183...
"accept 183, instead of generating ringing locally on outbound calls, because there are a number of companies (Microsoft, Intel, Metlife are ones I\'ve seen) that start their IVRs in 183."
*Oct 11 15:37:42.676: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x492CE530) with key=[898] to table
*Oct 11 15:37:42.676: //905/000000000000/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Oct 11 15:37:42.676: //905/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
*Oct 11 15:37:42.676: //905/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-H323
This a IPIP call: NULL peer_channel - peer_channels = 0x0, peer_param = 0x4964CA18, callID= 905, peer_callID = 904
*Oct 11 15:37:42.676: //905/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200000
*Oct 11 15:37:42.676: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : sip24.sip-me.net target_port : 5060
*Oct 11 15:37:42.676: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
*Oct 11 15:37:42.680: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 389 to table
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Media/sipSPICopyPeerDataToCCB: Firewall traversal is not enabled
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPI_ipip_call_setup: No video caps posted by peer
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPI_ipip_call_setup: xcoder high-density disabled
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPI_ipip_call_setup: Flow Mode set to FLOW_THROUGH
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 905, channels 0x0 caps 0x0
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
*Oct 11 15:37:42.680: //905/80BB30990800/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
*Oct 11 15:37:42.684: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddPrivacyandIdentityInfo: ccb->local_host_name,ccb->src_addr_str is NULL
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/Info/act_idle_continue_call_setup:
*Oct 11 15:37:42.684: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_SENT_DNS)
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS)  to (STATE_IDLE, SUBSTATE_SENT_DNS)
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x492CE530 key=6E51CFEA-12F011E2-8017B7AB-F260055A@10.0.101.9
*Oct 11 15:37:42.684: //905/80BB30990800/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 6E51CFEA-12F011E2-8017B7AB-F260055A@10.0.101.9
*Oct 11 15:37:42.684: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: TYPE SRV query for _sip._udp.sip24.sip-me.net and type:1
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_aaaa_query: DNS query for sip24.sip-me.net and type:1
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_query: TYPE A query successful for sip24.sip-me.net
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_aaaa_query: IP Address of sip24.sip-me.net is:
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_aaaa_query: 69.121.96.12
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 43
*Oct 11 15:37:42.692: //905/80BB30990800/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Oct 11 15:37:42.692: //905/80BB30990800/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 69.121.96.12,Port 5060, Transport 1, SentBy Port 5060
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Oct 11 15:37:42.692: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar host retrieved : sip24.sip-me.net
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Info/sipSPISendInvite: Associated container=0x4964C948 to Invite
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: msg=0x483963C0, addr=69.121.96.12, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x416E22E4
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x483963C0
*Oct 11 15:37:42.696: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x483963C0, addr=69.121.96.12, port=5060, connId=2 for UDP
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
*Oct 11 15:37:42.696: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
*Oct 11 15:37:42.696: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
*Oct 11 15:37:42.696: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8586182100@sip24.sip-me.net:5060 SIP/2.0
Date: Thu, 11 Oct 2012 15:37:42 GMT
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
From: <>8586181234@sip24.sip-me.net>;tag=3312828-C6
Allow-Events: telephone-event
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2159751321-484860167-134221826-167863753
Timestamp: 1349969862
Content-Length: 0
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <>8586182100@sip24.sip-me.net>
Contact: <8586181234>
Expires: 180
Call-ID: 6E51CFEA-12F011E2-8017B7AB-F260055A@10.0.101.9
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70B2639
CSeq: 101 INVITE
Max-Forwards: 70
*Oct 11 15:37:42.724: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.121.96.12]:5060
*Oct 11 15:37:42.724: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 11 15:37:42.724: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4875B174
*Oct 11 15:37:42.724: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4875B174, addr=69.121.96.12, port=5060, connid=2, transport=UDP
*Oct 11 15:37:42.724: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 11 15:37:42.724: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70B2639;received=121.1.2.9
To: <>8586182100@sip24.sip-me.net>;tag=as5af3ebaf
CSeq: 101 INVITE
User-Agent: packetrino
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="59e96ccd"
Content-Length: 0
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: msg=0x4961E570, addr=69.121.96.12, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x00000000
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4961E570
*Oct 11 15:37:42.728: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4961E570, addr=69.121.96.12, port=5060, connId=2 for UDP
*Oct 11 15:37:42.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Info/sipSPIGenerateAuthorizationResponse: HA1 is: 8d3e23df7b2e2b39752fe99a2e41073b
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Oct 11 15:37:42.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Info/sipSPISendInvite: Associated container=0x4964C948 to Invite
*Oct 11 15:37:42.728: //905/80BB30990800/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
*Oct 11 15:37:42.732: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: msg=0x483963C0, addr=69.121.96.12, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x416E22E4
*Oct 11 15:37:42.732: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 11 15:37:42.732: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Oct 11 15:37:42.732: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x483963C0
*Oct 11 15:37:42.732: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x483963C0, addr=69.121.96.12, port=5060, connId=2 for UDP
*Oct 11 15:37:42.732: //905/80BB30990800/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
*Oct 11 15:37:42.732: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
*Oct 11 15:37:42.732: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
*Oct 11 15:37:42.732: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8586182100@sip24.sip-me.net:5060 SIP/2.0
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Sent:
Min-SE:  1800
Content-Length: 0
Proxy-Authorization: Digest username="user_name",realm="asterisk",uri="sip:8586182100@sip24.sip-me.net:5060",response="cafa42a4d6152996172a85329c2e36c1",nonce="59e96ccd",algorithm=MD5
Expires: 180
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70CF22
CSeq: 102 INVITE
Max-Forwards: 70
*Oct 11 15:37:42.760: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.121.96.12]:5060
*Oct 11 15:37:42.760: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 11 15:37:42.760: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4875B174
*Oct 11 15:37:42.760: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4875B174, addr=69.121.96.12, port=5060, connid=2, transport=UDP
*Oct 11 15:37:42.760: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 11 15:37:42.760: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70CF22;received=121.1.2.9
CSeq: 102 INVITE
Supported: replaces
Contact: <8586182100>
Content-Length: 0
*Oct 11 15:37:42.760: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
*Oct 11 15:37:45.068: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.121.96.12]:5060
*Oct 11 15:37:45.068: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 11 15:37:45.068: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4875B174
*Oct 11 15:37:45.068: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4875B174, addr=69.121.96.12, port=5060, connid=2, transport=UDP
*Oct 11 15:37:45.068: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 11 15:37:45.068: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <>8586182100@sip24.sip-me.net>;tag=as104fbfbe
CSeq: 102 INVITE
Supported: replaces
Content-Type: application/sdp
Content-Length: 334
v=0
o=root 1763 1763 IN IP4 69.121.96.12
s=session
c=IN IP4 69.121.96.12
t=0 0
m=audio 14774 RTP/AVP 0 8 3 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
*Oct 11 15:37:45.072: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: Attribute mid, level 1 instance 1 not found.
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.101.9
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
*Oct 11 15:37:45.072: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
*Oct 11 15:37:45.072: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved.
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
*Oct 11 15:37:45.072: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Oct 11 15:37:45.072: //905/80BB30990800/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
    stream_type=voice+dtmf (1), dest_ip_address=69.121.96.12, dest_port=14774
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Preferred Codec        : g711ulaw, bytes :160
    Preferred  DTMF relay  : rtp-nte
    Preferred NTE payload  : 101
    Early Media            : No
    Delayed Media          : Yes
    Bridge Done            : No
    New Media              : No
    DSP DNLD Reqd          : No
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.101.9
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 905 peer 904 flags 0x200001 state STATE_RECD_PROCEEDING
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 905, sdp 0x497C12C0 channels 0x492CF7A4
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/copy_channels:
callId 905 size 0 ptr 0x48EB9F64)
Hndl ptype 0 mline 1
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
*Oct 11 15:37:45.076: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
Adding codec 5 ptype 0 time 20, bytes 160  as channel 0 mline 1 ss 0 69.121.96.12:14774
Hndl ptype 8 mline 1
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 6
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=20, media_ndx=1
*Oct 11 15:37:45.076: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :20, codecbytes: 160
Adding codec 6 ptype 8 time 20, bytes 160  as channel 1 mline 1 ss 0 69.121.96.12:14774
Hndl ptype 3 mline 1
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec gsmfr
Hndl ptype 18 mline 1
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
Hndl ptype 101 mline 1
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 905, dtmf = 6
*Oct 11 15:37:45.076: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 6
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 905 flags 0x100 state STATE_RECD_PROCEEDING
Report initial call media
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=-1, current_seq_num=0x2656
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=-1, current_seq_num=0x0
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/ccsip_do_caps_ind: Load DSP with codec: g711ulaw, Bytes=160
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/ccsip_update_srtp_caps:  4754: Posting Remote SRTP caps to other callleg.
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Stream type            : voice+dtmf
      Media line             : 1
      State                  : STREAM_ADDING (2)
      Stream address type    : 1
      Callid                 : -1
      Negotiated Codec       : g711ulaw, bytes :160
      Nego. Codec payload    : 0 (tx), 0 (rx)
      Negotiated DTMF relay  : rtp-nte
      Negotiated NTE payload : 101 (tx), 101 (rx)
      Negotiated CN payload  : 0
      Media Srce Addr/Port   : [10.0.101.9]:0
      Media Dest Addr/Port   : [69.121.96.12]:14774
*Oct 11 15:37:45.080: //905/80BB30990800/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*Oct 11 15:37:45.080: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
*Oct 11 15:37:45.080: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
*Oct 11 15:37:45.084: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
*Oct 11 15:37:45.084: //905/80BB30990800/SIP/Info/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
*Oct 11 15:37:45.084: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Oct 11 15:37:45.084: //905/80BB30990800/SIP/Info/HandleSIP1xxSessionProgress: Transaction Complete. Lock on Facilities released.
*Oct 11 15:37:45.084: //905/80BB30990800/SIP/Info/ccsip_bridge: confID = 7, srcCallID = 905, dstCallID = 904
*Oct 11 15:37:45.084: //905/80BB30990800/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 905/904
*Oct 11 15:37:45.084: //905/80BB30990800/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=905
*Oct 11 15:37:45.088: //905/80BB30990800/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-H323
*Oct 11 15:37:45.088: //905/80BB30990800/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1126144576, ccb xmitFunc = 1126144576
*Oct 11 15:37:45.088: //905/80BB30990800/SIP/Info/ccsip_bridge: ccsip_bridge: Delayed Media case
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: Entry
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=905, current_seq_num=0x0
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=905, current_seq_num=0x0
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x200401
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: No video caps detected in the caps posted by peer leg
*Oct 11 15:37:45.108: //905/80BB30990800/SIP/Info/ccsip_caps_ind: Setting CAPS_RECEIVED flag
*Oct 11 15:37:45.112: //905/80BB30990800/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
*Oct 11 15:37:45.116: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Oct 11 15:37:45.116: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 153)
*Oct 11 15:37:45.116: //905/80BB30990800/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 904 chans 0x497C42D4 event 153 flags 0xC06018 0x100 0x200421 data 0x497C42D4
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 904  chans 0x497C42D4 event 153 flags 0xC06018 0x100 0x200421 data 0x497C42D4
*Oct 11 15:37:45.116: //905/80BB30990800/SIP/Info/sipSPI_ipip_send_channel_ind_with_symmetry:
CCSIP: Sending OPEN_CHANNEL_IND
                            with codec g711ulaw AND OPEN_CHANNEL_ACK
*Oct 11 15:37:45.116: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Oct 11 15:37:45.220: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Oct 11 15:37:45.220: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 154)
*Oct 11 15:37:45.220: //905/80BB30990800/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 904 chans 0x49768E0C event 154 flags 0xC06018 0x100 0x200421 data 0x49768E0C
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_ACK: peer ID 904 chans 0x49768E0C event 154 flags 0xC06018 0x100 0x200421 data 0x49768E0C
*Oct 11 15:37:45.224: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type =
                                         SIPSPI_EV_CC_NEW_MEDIA for CC_EV_H245_OPEN_CHANNEL_ACK!: peer ID 904 chans 0x49768E0C event 154 flags 0xC06018 0x100 0x200421 data 0x49768E0C
*Oct 11 15:37:45.224: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Oct 11 15:37:45.224: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 26
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 905 ft: 1, inc 0, 10.1.101.201:20882, codec 5
CCSIP:callid 905 state STATE_RECD_PROCEEDING
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 905, channels 0x49768E0C caps 0x497C75D8
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 905, peer dtmf = 0
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: callid = 905, peer not doing RFC2833, peer dtmf = 0, enable NTE_ASSUMED
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: callid = 905, this leg negotiated dtmf = 6, peer dtmf = 0, nte/oob DTMF_IWF enabled.
nego mline 1 dtmf 0 ss 0 ret 12
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x203421
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
retreive codec 5 ptype 0 time 20 bytes 160
stream negotiated codec retreive codec 5
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 905) to the VOIP RTP library
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Media/sipSPIAddStream: Reserved port 16798 for rtp/rtcp
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.101.9
*Oct 11 15:37:45.224: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 10.0.101.9, lport = 16798, raddr = 69.121.96.12, rport=14774, do_rtcp=TRUE
    src_callid = 905, dest_callid = 904, stream type = voice+dtmf, stream direction = SENDRECV
    media_ip_addr = 69.121.96.12, vrf tableid = 0 media_addr_type = 1
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Info/sipSPICreateRtpSession: sess: 48802D08 do_rtcp:1
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Info/sipSPIUpdateRtcpSession:
DTMF inb/oob iwf enabled 101
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Media/sipSPIGetNewLocalMediaDirection:
    New Remote Media Direction = SENDRECV
    Present Local Media Direction = SENDRECV
    New Local Media Direction = SENDRECV
    retVal = 0
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/State/sipSPIChangeStreamState: Stream (callid =  905)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=16798
*Oct 11 15:37:45.228: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 16798
SIP update src sdp, negoitated codec 5, payload type 0
*Oct 11 15:37:45.228: //905/80BB30990800/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
*Oct 11 15:37:47.192: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.121.96.12]:5060
*Oct 11 15:37:47.192: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 11 15:37:47.192: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4875B174
*Oct 11 15:37:47.196: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4875B174, addr=69.121.96.12, port=5060, connid=2, transport=UDP
*Oct 11 15:37:47.196: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 11 15:37:47.196: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 334
v=0
o=root 1763 1764 IN IP4 69.121.96.12
s=session
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*Oct 11 15:37:47.196: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Oct 11 15:37:47.196: //905/80BB30990800/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
*Oct 11 15:37:47.196: //905/80BB30990800/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.101.9
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
*Oct 11 15:37:47.200: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
*Oct 11 15:37:47.200: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
*Oct 11 15:37:47.200: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sip_do_nse_negotiation: Remote NSE payload = local one = 0, Use it
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=14774 new=14774
*Oct 11 15:37:47.200: //905/80BB30990800/SIP/Media/sipSPIGetNewLocalMediaDirection:
    retVal = 0
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Early Media            : No
    Delayed Media          : Yes
    Bridge Done            : Yes
    New Media              : Yes
    DSP DNLD Reqd          : Yes
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.101.9
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 905 peer 904 flags 0x207405 state STATE_RECD_PROCEEDING
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 905, sdp 0x48802F54 channels 0x492CF7A4
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/copy_channels:
callId 905 size 240 ptr 0x487310B4)
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
*Oct 11 15:37:47.204: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec gsmfr
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
Call 905 dtmf ptype 101 nte/oob enabled
*Oct 11 15:37:47.204: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 905, dtmf = 6
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report change in call setup media
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/ccsip_update_srtp_caps:  4754: Posting Remote SRTP caps to other callleg.
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Media line             : 1
      State                  : STREAM_CHANGING (4)
      Callid                 : -1
      Media Srce Addr/Port   : [10.0.101.9]:16798
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 905) to the VOIP RTP library
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.101.9
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/sipSPICreateRtpSession: sess: 48802D08 do_rtcp:1
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPICreateRtpSession: stun is disabled
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Info/sipSPIUpdateRtcpSession:
*Oct 11 15:37:47.208: //905/80BB30990800/SIP/Media/sipSPIGetNewLocalMediaDirection:
    retVal = 0
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/State/sipSPIChangeStreamState: Stream (callid =  905)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4825A31C
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/sipSPIUpdateRtcpSession:
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Media/sipSPIGetNewLocalMediaDirection:
    retVal = 0
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Oct 11 15:37:47.212: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
*Oct 11 15:37:47.212: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
*Oct 11 15:37:47.212: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/sipSPIShrlCall: Check peer: 1 for Shared-Line call, callid: 905
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/sipSPICreateAndStartRtpTimer:
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/ccsip_api_call_connected: SDP_INFO PTR 0x4975EF00
*Oct 11 15:37:47.212: //905/80BB30990800/SIP/Info/ccsip_api_call_connected: CCSIP: outgoing send ACK with SDP
*Oct 11 15:37:47.212: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (SIP_STATE_RECD_SUCCESS, SUBSTATE_NONE)
*Oct 11 15:37:47.216: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Info/act_handle_app_media_event: method = 107 state = 24
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_ANSWER
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Info/sipSPISendAck: Associated container=0x4964CC08 to Ack
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: msg=0x4961E574, addr=69.121.96.12, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x416E3694
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4961E574
*Oct 11 15:37:47.216: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4961E574, addr=69.121.96.12, port=5060, connId=2 for UDP
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (SIP_STATE_RECD_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x492CE530
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 8586181234
Called Number            : 8586182100
Source IP Address (Sig  ): 10.0.101.9
Destn SIP Req Addr:Port  : 69.121.96.12:5060
Destn SIP Resp Addr:Port : 69.121.96.12:5060
Destination Name         : sip24.sip-me.net
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 10.0.101.9
Source IP Port    (Media): 16798
Destn  IP Address (Media): 69.121.96.12
Destn  IP Port    (Media): 14774
Orig Destn IP Address:Port (Media): [ - ]:0
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
*Oct 11 15:37:47.216: //905/80BB30990800/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Oct 11 15:37:47.232: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8586182100@69.121.96.12:5060 SIP/2.0
Content-Length: 241
Content-Disposition: session;handling=required
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70D6C1
CSeq: 102 ACK
Max-Forwards: 70
v=0
o=CiscoSystemsSIP-GW-UserAgent 5646 1618 IN IP4 10.0.101.9
s=SIP Call
c=IN IP4 10.0.101.9
t=0 0
m=audio 16798 RTP/AVP 0 101
c=IN IP4 10.0.101.9
a=fmtp:101 0-16
a=ptime:20
*Oct 11 15:37:49.996: //905/80BB30990800/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4825A31C
*Oct 11 15:37:50.000: //905/80BB30990800/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
*Oct 11 15:37:50.000: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Oct 11 15:37:50.004: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
*Oct 11 15:37:50.004: //905/80BB30990800/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Oct 11 15:37:50.004: //905/80BB30990800/SIP/Info/sipSPIGenerateAuthorizationResponse: HA1 is: 8d3e23df7b2e2b39752fe99a2e41073b
*Oct 11 15:37:50.004: //905/80BB30990800/SIP/Info/sipSPISendBye: Associated container=0x4964C9A0 to Bye
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: msg=0x4961E574, addr=69.121.96.12, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x416E30A0
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4961E574
*Oct 11 15:37:50.008: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4961E574, addr=69.121.96.12, port=5060, connId=2 for UDP
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Oct 11 15:37:50.008: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Oct 11 15:37:50.012: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:8586182100@69.121.96.12:5060 SIP/2.0
Reason: Q.850;cause=16
Timestamp: 1349969870
Content-Length: 0
Proxy-Authorization: Digest username="user_name",realm="asterisk",uri="sip:8586182100@69.121.96.12:5060",response="a4b3c1250bc501bfb8423a865ae645c5",nonce="59e96ccd",algorithm=MD5
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70E8C2
CSeq: 103 BYE
Max-Forwards: 70
*Oct 11 15:37:50.280: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.121.96.12]:5060
*Oct 11 15:37:50.280: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Oct 11 15:37:50.280: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4875B174
*Oct 11 15:37:50.280: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4875B174, addr=69.121.96.12, port=5060, connid=2, transport=UDP
*Oct 11 15:37:50.280: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Oct 11 15:37:50.280: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70E8C2;received=121.1.2.9
CSeq: 103 BYE
Supported: replaces
Content-Length: 0
*Oct 11 15:37:50.280: //905/80BB30990800/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:5356078 ConnTime 5355771
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/State/sipSPIChangeState: 0x492CE530 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 389
*Oct 11 15:37:50.284: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[898] removed.
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x492CE530 key=6E51CFEA-12F011E2-8017B7AB-F260055A@10.0.101.9
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Oct 11 15:37:50.284: //905/80BB30990800/SIP/Info/ccsip_qos_cleanup: Entry
*Oct 11 15:37:50.288: //905/80BB30990800/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
*Oct 11 15:37:50.288: //905/80BB30990800/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 492CE530
*Oct 11 15:37:50.288: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[898]
we could see that the provider sends the 183 session progress with SDP contents as below.
Received:
.Via: SIP/2.0/UDP 10.0.101.9:5060;branch=z9hG4bK70CF22;received=121.1.2.9
.From: <>8586181234@sip24.sip-me.net>;tag=3312828-C6
.To: <>8586182100@sip24.sip-me.net>;tag=as104fbfbe
.Call-ID: 6E51CFEA-12F011E2-8017B7AB-F260055A@10.0.101.9
.CSeq: 102 INVITE
.User-Agent: packetrino
.Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
.Supported: replaces
.Contact: <8586182100>
.Content-Type: application/sdp
.Content-Length: 334
v=0
.o=root 1763 1763 IN IP4 69.121.96.12
.s=session
.c=IN IP4 69.121.96.12
.t=0 0
.m=audio 14774 RTP/AVP 0 8 3 18 101
.a=rtpmap:0 PCMU/8000
.a=rtpmap:8 PCMA/8000
.a=rtpmap:3 GSM/8000
.a=rtpmap:18 G729/8000
.a=fmtp:18 annexb=no
.a=rtpmap:101 telephone-event/8000
.a=fmtp:101 0-16
.a=silenceSupp:off - - - -
.a=ptime:20
.a=sendrecv
>> It indicates that the service provider is generating the ringback tone.however to confirm the same, we would need to capture the "debug voip ccapi inout" along with "debug ccsip all" for a test call.
>> to capture multiple debugs: https://supportforums.cisco.com/docs/DOC-16310
>> Also, could you please post the running config of the sip gateway?
>> is this gateway connected to CUCM as H.323 GW?
Below is the output of the debug voip ccapi inout
*Oct 11 23:40:34.418: //-1/00B0710E1900/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=FirstName LastName
   ----- ccCallInfo IE subfields -----
   cisco-ani=858-295-8888
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8009993355
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Oct 11 23:40:34.418: //-1/00B0710E1900/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48336EE0, Call Info(
   Calling Number=858-295-8888,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8009993355(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1420
*Oct 11 23:40:34.418: //-1/00B0710E1900/CCAPI/ccCheckClipClir:
   In: Calling Number=858-295-8888(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Oct 11 23:40:34.422: //-1/00B0710E1900/CCAPI/ccCheckClipClir:
   Out: Calling Number=858-295-8888(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Oct 11 23:40:34.422: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 11 23:40:34.422: :cc_get_feature_vsa malloc success
*Oct 11 23:40:34.422:  cc_get_feature_vsa count is 1
*Oct 11 23:40:34.422: :FEATURE_VSA attributes are: feature_name:0,feature_time:1197531656,feature_id:47
*Oct 11 23:40:34.422: //1420/00B0710E1900/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=858-295-8888(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8009993355(TON=Unknown, NPI=Unknown))
*Oct 11 23:40:34.422: //1420/00B0710E1900/CCAPI/cc_process_call_setup_ind:
   Event=0x490C14D0
*Oct 11 23:40:34.422: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8009993355
*Oct 11 23:40:34.426: //1420/00B0710E1900/CCAPI/ccCallSetContext:
   Context=0x475E4904
*Oct 11 23:40:34.426: //1420/00B0710E1900/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 1420 with tag 1 to app "_ManagedAppProcess_Default"
*Oct 11 23:40:34.426: //1420/00B0710E1900/CCAPI/ccCallProceeding:
*Oct 11 23:40:34.426: //1420/00B0710E1900/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x475E5844, Progress Indication=NULL(0)
*Oct 11 23:40:34.430: //1420/00B0710E1900/CCAPI/ccCheckClipClir:
*Oct 11 23:40:34.430: //1420/00B0710E1900/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=8009993355, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=FirstName LastName, Final Destination Flag=TRUE,
   Guid=00B0710E-4957-7107-1900-2F020A0165C9, Outgoing Dial-peer=1
*Oct 11 23:40:34.430: //1420/00B0710E1900/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=8009993355
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Oct 11 23:40:34.430: //1420/00B0710E1900/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x489F756C, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=858-295-8888,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=8009993355(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Oct 11 23:40:34.430: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 11 23:40:34.430: :cc_get_feature_vsa malloc success
*Oct 11 23:40:34.430:  cc_get_feature_vsa count is 2
*Oct 11 23:40:34.430: :FEATURE_VSA attributes are: feature_name:0,feature_time:1197531432,feature_id:48
*Oct 11 23:40:34.430: //1421/00B0710E1900/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Oct 11 23:40:34.434: //1421/00B0710E1900/CCAPI/ccCallSetContext:
   Context=0x475E57F4
*Oct 11 23:40:34.434: //1420/00B0710E1900/CCAPI/ccSaveDialpeerTag:
*Oct 11 23:40:34.434: //1421/00B0710E1900/CCAPI/cc_api_call_proceeding:
   Interface=0x489F756C, Progress Indication=NULL(0)
*Oct 11 23:40:36.430: //1421/00B0710E1900/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1421,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Oct 11 23:40:36.430: //1421/00B0710E1900/CCAPI/cc_api_event_indication:
   Event=90, Call Id=1421
   Event Is Sent To Conferenced SPI(s) Directly
*Oct 11 23:40:36.430: //1421/00B0710E1900/CCAPI/cc_api_call_cut_progress:
   Interface=0x489F756C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
*Oct 11 23:40:36.434: //1420/00B0710E1900/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
*Oct 11 23:40:36.434: //1421/00B0710E1900/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
*Oct 11 23:40:36.434: //1420/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x48801C44, callID1=0x58C, callID2=0x58D, tag=0x0)
   (confID=0x48801C44, callID1=0x58C, gcid=0-0-0-0, tag=0x0)
*Oct 11 23:40:36.434: //1421/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x48801C44, callID2=0x58D, gcid=0-0-0-0, tag=0x0)
*Oct 11 23:40:36.434: //1420/00B0710E1900/CCAPI/ccConferenceCreate:
   Conference Id=0x48801C44, Call Id1=1420, Call Id2=1421, Tag=0x0
*Oct 11 23:40:36.438: //1420/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 11 23:40:36.438: cc_api_get_xcode_stream : 4510
*Oct 11 23:40:36.438: //1420/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x18, Source Interface=0x48336EE0, Source Call Id=1420,
   Destination Call Id=1421, Disposition=0x0, Tag=0x0
*Oct 11 23:40:36.438: //1421/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 11 23:40:36.438: //1421/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x18, Source Interface=0x489F756C, Source Call Id=1421,
   Destination Call Id=1420, Disposition=0x0, Tag=0x0
*Oct 11 23:40:36.438: //1420/00B0710E1900/CCAPI/cc_generic_bridge_done:
*Oct 11 23:40:36.438: //1420/00B0710E1900/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x18, Destination Call Id=1421)
*Oct 11 23:40:36.438: //1421/00B0710E1900/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x18, Destination Call Id=1420)
*Oct 11 23:40:36.442: //1420/00B0710E1900/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x18, Call Id1=1420, Call Id2=1421
*Oct 11 23:40:36.442: //1420/00B0710E1900/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=1420
*Oct 11 23:40:36.442: //1421/00B0710E1900/CCAPI/cc_api_get_called_ccm_detected:
*Oct 11 23:40:36.466: //1420/00B0710E1900/CCAPI/cc_api_caps_ind:
   Destination Interface=0x489F756C, Destination Call Id=1421, Source Call Id=1420,
   Caps(Codec=0x3, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
*Oct 11 23:40:36.466: //1421/00B0710E1900/CCAPI/cc_api_caps_ack:
   Destination Interface=0x48336EE0, Destination Call Id=1420, Source Call Id=1421,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
*Oct 11 23:40:36.466: //1420/00B0710E1900/CCAPI/cc_api_caps_ack:
   Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0x0), Vad=Invalid(0x0),
   Modem=OFF(0x0), Codec Bytes=0, Signal Type=0, Seq Num Start=0)
*Oct 11 23:40:36.470: //1420/00B0710E1900/CCAPI/cc_api_event_indication:
   Event=153, Call Id=1420
*Oct 11 23:40:36.474: //1421/00B0710E1900/CCAPI/cc_api_event_indication:
   Event=154, Call Id=1421
*Oct 11 23:40:36.522: //1420/00B0710E1900/CCAPI/cc_api_event_indication:
   Event=154, Call Id=1420
*Oct 11 23:40:37.270: //1421/00B0710E1900/CCAPI/cc_api_event_indication:
*Oct 11 23:40:37.270: //1421/00B0710E1900/CCAPI/cc_api_call_connected:
   Interface=0x489F756C, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
*Oct 11 23:40:37.274: //1421/00B0710E1900/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Oct 11 23:40:37.278: //1420/00B0710E1900/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
*Oct 11 23:40:37.278: //1421/00B0710E1900/CCAPI/cc_api_get_called_ccm_detected:
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Oct 11 23:40:37.278: //1420/00B0710E1900/CCAPI/ccCallNotify:
Below is the running config
Current configuration : 2756 bytes
version 12.4
service password-encryption
hostname ***********
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name *****.local
ip name-server 100.0.100.100
ip name-server 100.1.100.100
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
  h225 timeout tcp establish 2
  h225 timeout call-proceeding 1
  h225 timeout setup 3
  call start fast
  telephony-service ccm-compatible
  ccm-compatible
voice-card 0
dsp services dspfarm
username **** privilege 15 secret 5 ****
archive
log config
  hidekeys
ip ssh version 1
interface Port-channel1
ip address 10.0.101.9 255.255.255.0
h323-gateway voip interface
h323-gateway voip h323-id C2811
h323-gateway voip bind srcaddr 10.0.101.9
interface FastEthernet0/0
no ip address
duplex auto
speed auto
channel-group 1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
channel-group 1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.101.40
no ip http server
no ip http secure-server
access-list 11 remark List for SNMP access
access-list 11 permit 100.0.100.155
access-list 11 permit 100.0.100.127
snmp-server community public RO 11
snmp-server ifindex persist
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer voice 1 voip
description This is for outgoing calls through the SIP...
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
session transport udp
incoming called-number 9T
dtmf-relay rtp-nte
sip-ua
credentials username **** password 7 **** realm asterisk
authentication username **** password 7 **** realm asterisk
no remote-party-id
retry invite 2
retry register 2
registrar dns:sip24.****.net expires 3600
sip-server dns:sip24.****.net
host-registrar
line con 0
login local
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
end
>> The service providers are sending the inband ringback tone to the SIP gateway.
>> ringback received in outbound call leg from ISP
.Interface=0x489F756C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
.Cause Value=0
.Call Entry(Responsed=TRUE)
>> ringback is passed to inbound call leg as below
.Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
.Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
>> could you please answer the below questions?
1) is this new setup or was it working fine?
2) if it is new setup, is there any specific reason you have configured this gw as h.323 to sip gateway?
3) if you need it as h.323 to sip cube, could you please provide the below debugs?
     - debug voip ccapi inout
     - debug h225 q931
     - debug h225 asn1
     - debug h245 asn1
     - debug ccsip all
I need all of above debugs for the single test call and also detailed ccm trace please.
4) if no, can you use it as sip to sip cube by creating a sip trunk from cucm to this gw?
5) also, in your existing sip configuration, i dont find the source interface binding for media and signalling. could you do that please?
//Suresh Please rate all the useful posts.
eric.butcher
It looks like you're doing CUCM > GW as H323 right?
Make sure the MRGL of the h323 gateway has access to the announciators, and then under service parameters, look for the Device - H.323 section.  There is a service parameter labelled "Send h225 User Info Message".
Set that to "Use ANN for ringback" and see if it fixes your issue.
That, or disable CEF. (Disabling CEF may cause your router CPU to spike and your router to effectively crash, so I'd avoid this one.)
I have made these changes on both CMs, but is there a service or something I need to restart? I reset the gateway and still don't hear a ringback. I have the MRGL w/ 2 ANNs from both CMs in there.
Make sure the Announciators and gateways are in a region where they an negotiate a common codec, and then try restarting the Cisco IP Voice Media Streaming Application
JUST to confirm:  You did change the service parameter, yes?
I have rebooted both CMs and it still doesn't work.
Would making the gateway a SIP instead of h323 simplify anything? The reason i did h323 is because all our other sites are done this way and we use SRST at remote sites. Does SRST work if the 2811 is SIP instead of h323?
Yes, SRST will still work if you do SIP between CUCM and the gateway.
