Ringback tone is not working.
Md.soriful
Hi everyone, i am fatcching ringback tone issue. I have collected loggs. I am unable to find the issue. if there kind engineer please help t
VOICE-GW-ROUTER-01#show logg
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Buffer logging: level debugging, 4993 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
Trap logging: level informational, 42 message lines logged
Log Buffer (10000000 bytes):
Check DTMF relay digit begin for 3way conf
001921: Sep 13 10:15:54.405: //22093/801ECFA16C00/CCAPI/cc_api_call_digit_end:
Consume mask is not set. Relaying Digit A to dstCallId 0x564C
001922: Sep 13 10:15:54.405: //22093/801ECFA16C00/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
001923: Sep 13 10:15:55.977: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x30F94910, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
001924: Sep 13 10:15:55.977: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001925: Sep 13 10:15:55.977: :cc_get_feature_vsa malloc success
001926: Sep 13 10:15:55.977: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001927: Sep 13 10:15:55.977: cc_get_feature_vsa count is 26
001928: Sep 13 10:15:55.981: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001929: Sep 13 10:15:55.981: :FEATURE_VSA attributes are: feature_name:0,feature_time:736933880,feature_id:12767
001930: Sep 13 10:15:55.981: //22117/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
001931: Sep 13 10:15:55.981: //22117/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x3057ED60
001932: Sep 13 10:15:55.981: //22117/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Interface=0x30F94910, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
001933: Sep 13 10:15:55.981: //22117/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
001934: Sep 13 10:15:55.989: //22117/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
001935: Sep 13 10:15:55.989: //22117/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
001936: Sep 13 10:15:55.989: //22117/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30F94910, Tag=0x0, Call Id=22117,
Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
001937: Sep 13 10:15:55.989: //22117/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
001938: Sep 13 10:15:55.989: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001939: Sep 13 10:15:55.989: :cc_free_feature_vsa freeing 2BECB7F0
001940: Sep 13 10:15:55.989: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001941: Sep 13 10:15:55.989: vsacount in free is 25
001942: Sep 13 10:15:55.993: //-1/00C0D2BD7300/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=ATM Cash Loading and Dispute
----- ccCallInfo IE subfields -----
cisco-ani=50648
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=901725802102
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
001943: Sep 13 10:15:55.993: //-1/00C0D2BD7300/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2AD996F4, Call Info(
Calling Number=50648,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901725802102(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=4, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=22118
001944: Sep 13 10:15:55.993: //-1/00C0D2BD7300/CCAPI/ccCheckClipClir:
In: Calling Number=50648(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
001945: Sep 13 10:15:55.993: //-1/00C0D2BD7300/CCAPI/ccCheckClipClir:
Out: Calling Number=50648(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
001946: Sep 13 10:15:55.993: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001947: Sep 13 10:15:55.993: :cc_get_feature_vsa malloc success
001948: Sep 13 10:15:55.993: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001949: Sep 13 10:15:55.993: cc_get_feature_vsa count is 26
001950: Sep 13 10:15:55.993: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001951: Sep 13 10:15:55.993: :FEATURE_VSA attributes are: feature_name:0,feature_time:736933880,feature_id:12768
001952: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=50648(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901725802102(TON=Unknown, NPI=Unknown))
001953: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/cc_process_call_setup_ind:
Event=0x2B4306B8
001954: Sep 13 10:15:55.993: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 901725802102
001955: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/ccCallSetContext:
Context=0x2BEE73E4
001956: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 22118 with tag 4 to app "_ManagedAppProcess_Default"
001957: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/ccCallProceeding:
001958: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=2, Params=0x306B38B8, Progress Indication=NULL(0)
001959: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/ccCheckClipClir:
In: Calling Number=09612001122(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
001960: Sep 13 10:15:55.993: //22118/00C0D2BD7300/CCAPI/ccCheckClipClir:
Out: Calling Number=09612001122(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
001961: Sep 13 10:15:55.997: //22118/00C0D2BD7300/CCAPI/ccCallSetupRequest:
Destination Pattern=9T, Called Number=01725802102, Digit Strip=FALSE
001962: Sep 13 10:15:55.997: //22118/00C0D2BD7300/CCAPI/ccCallSetupRequest:
Calling Number=09612001122(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01725802102(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=ATM Cash Loading and Dispute
Account Number=ATM Cash Loading and Dispute, Final Destination Flag=TRUE,
Guid=00C0D2BD-E935-F113-7300-7701AC16636A, Outgoing Dial-peer=2
001963: Sep 13 10:15:55.997: //22118/00C0D2BD7300/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=09612001122
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01725802102
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
001964: Sep 13 10:15:55.997: //22118/00C0D2BD7300/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x2B17C21C, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=09612001122,(Calling Name=ATM Cash Loading and Dispute)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01725802102(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
001965: Sep 13 10:15:55.997: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001966: Sep 13 10:15:55.997: :cc_get_feature_vsa malloc success
001967: Sep 13 10:15:55.997: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001968: Sep 13 10:15:55.997: cc_get_feature_vsa count is 27
001969: Sep 13 10:15:55.997: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
001970: Sep 13 10:15:55.997: :FEATURE_VSA attributes are: feature_name:0,feature_time:736933432,feature_id:12769
001971: Sep 13 10:15:55.997: //22119/00C0D2BD7300/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
001972: Sep 13 10:15:55.997: //22119/00C0D2BD7300/CCAPI/ccCallSetContext:
Context=0x306B3868
001973: Sep 13 10:15:55.997: //22118/00C0D2BD7300/CCAPI/ccSaveDialpeerTag:
001974: Sep 13 10:15:55.997: //22119/00C0D2BD7300/CCAPI/cc_api_call_proceeding:
Interface=0x2B17C21C, Progress Indication=NULL(0)
001975: Sep 13 10:15:55.997: //22119/00C0D2BD7300/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:01725802102@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31501290
From: "ATM Cash Loading and Dispute" <sip:09612001122@172.16.252.12>;tag=13C1D744-10A1
To: <sip:01725802102@172.16.252.12>
Date: Mon, 13 Sep 2021 10:15:55 GMT
Call-ID: 6AE26486-13B211EC-9562ABF4-A51D28B2@172.19.20.142
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0012636861-3912626451-1929410305-2887148394
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1631528155
Contact: <sip:09612001122@172.19.20.142:5060>
Expires: 180
Allow-Events: telephone-event
Content-Length: 0
001976: Sep 13 10:15:56.005: //22119/00C0D2BD7300/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31501290;received=172.19.20.142;rport=50179
CSeq: 101 INVITE
Server: Asterisk PBX 16.6.1
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Session-Expires: 1800;refresher=uas
Contact: <sip:01725802102@172.16.252.12:5060>
Content-Length: 0
001977: Sep 13 10:15:58.457: //22103/00F0BFAA6E00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 181 Call is being forwarded
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31422351;received=172.19.20.142;rport=50179
From: "In charge Monitoring Unit" <sip:09612001122@172.16.252.12>;tag=13C15C58-2172
To: <sip:01840708082@172.16.252.12>;tag=as477d1e18
Call-ID: 5820C2A1-13B211EC-954DABF4-A51D28B2@172.19.20.142
CSeq: 101 INVITE
Contact: <sip:01840708082@172.16.252.12:5060>
Diversion: <sip:01840708082@172.16.252.12>;reason=unconditional
Content-Length: 0
001978: Sep 13 10:15:58.457: //22103/00F0BFAA6E00/CCAPI/cc_api_call_cut_progress:
Interface=0x2B17C21C, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255),
Cause Value=0
001979: Sep 13 10:15:58.457: //22103/00F0BFAA6E00/CCAPI/cc_api_call_cut_progress:
Call Entry(Responsed=TRUE)
001980: Sep 13 10:15:58.457: //22102/00F0BFAA6E00/CCAPI/ccCallProgIndProgress:
001981: Sep 13 10:15:58.457: //22103/00F0BFAA6E00/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
001982: Sep 13 10:15:58.457: //22103/00F0BFAA6E00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 486 Busy here
CSeq: 101 INVITE
Content-Length: 0
001983: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/cc_api_call_disconnected:
Cause Value=17, Interface=0x2B17C21C, Call Id=22103
001984: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
001985: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
001986: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=22103
001987: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/ccConferenceDestroy:
Conference Id=0x131E, Tag=0x0
001988: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x131E, Source Interface=0x2AD996F4, Source Call Id=22102,
Destination Call Id=22103, Disposition=0x0, Tag=0x0
001989: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x131E, Source Interface=0x2B17C21C, Source Call Id=22103,
Destination Call Id=22102, Disposition=0x0, Tag=0x0
001990: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/cc_generic_bridge_done:
001991: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01840708082@172.16.252.12:5060 SIP/2.0
Date: Mon, 13 Sep 2021 10:15:24 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
001992: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
001993: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/ccCallDisconnect:
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
001994: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B17C21C, Tag=0x0, Call Id=22103,
Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
001995: Sep 13 10:15:58.461: //22103/00F0BFAA6E00/CCAPI/cc_api_call_disconnect_done:
001996: Sep 13 10:15:58.461: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001997: Sep 13 10:15:58.461: :cc_free_feature_vsa freeing 2BECAD70
001998: Sep 13 10:15:58.461: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
001999: Sep 13 10:15:58.461: vsacount in free is 26
002000: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
002001: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/ccCallDisconnect:
002002: Sep 13 10:15:58.461: //22102/00F0BFAA6E00/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
002003: Sep 13 10:15:58.465: //22102/00F0BFAA6E00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2AD996F4, Tag=0x0, Call Id=22102,
002004: Sep 13 10:15:58.465: //22102/00F0BFAA6E00/CCAPI/cc_api_call_disconnect_done:
002005: Sep 13 10:15:58.465: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002006: Sep 13 10:15:58.465: :cc_free_feature_vsa freeing 2BECA3D0
002007: Sep 13 10:15:58.465: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002008: Sep 13 10:15:58.465: vsacount in free is 25
002009: Sep 13 10:16:00.605: //22119/00C0D2BD7300/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:01725802102@172.16.252.12>;tag=as59436d88
CSeq: 101 INVITE
Content-Type: application/sdp
Require: timer
Content-Length: 275
v=0
o=root 764222724 764222724 IN IP4 172.16.252.12
s=Asterisk PBX 16.6.1
c=IN IP4 172.16.252.12
t=0 0
m=audio 16812 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
SIP: Attribute mid, level 1 instance 1 not found.
002010: Sep 13 10:16:00.605: //22119/00C0D2BD7300/CCAPI/cc_api_event_indication:
Event=91, Call Id=22119
002011: Sep 13 10:16:00.605: //22119/00C0D2BD7300/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
002012: Sep 13 10:16:00.605: //22119/00C0D2BD7300/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=22119,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
002013: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
002014: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/cc_api_call_cut_progress:
Interface=0x2B17C21C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
Cause Value=0
002015: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/cc_api_call_cut_progress:
002016: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
002017: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/ccCallCutProgress:
002018: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/cc_api_get_called_ccm_detected:
002019: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/ccConferenceCreate:
(confID=0x2BEE95E8, callID1=0x5666, gcid=0-0-0-0, tag=0x0)
002020: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/ccConferenceCreate:
(confID=0x2BEE95E8, callID2=0x5667, gcid=0-0-0-0, tag=0x0)
002021: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/ccConferenceCreate:
Conference Id=0x2BEE95E8, Call Id1=22118, Call Id2=22119, Tag=0x0
002022: Sep 13 10:16:00.609: //22118/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002023: Sep 13 10:16:00.609: cc_api_get_xcode_stream : 4702
002024: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/cc_api_bridge_done:
Conference Id=0x1323, Source Interface=0x2AD996F4, Source Call Id=22118,
Destination Call Id=22119, Disposition=0x0, Tag=0x0
002025: Sep 13 10:16:00.609: //22119/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002026: Sep 13 10:16:00.609: cc_api_get_xcode_stream : 4702
002027: Sep 13 10:16:00.609: //22119/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002028: Sep 13 10:16:00.609: cc_api_get_xcode_stream : 4702
002029: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/cc_api_bridge_done:
Conference Id=0x1323, Source Interface=0x2B17C21C, Source Call Id=22119,
Destination Call Id=22118, Disposition=0x0, Tag=0x0
002030: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/cc_generic_bridge_done:
002031: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1323, Destination Call Id=22119)
002032: Sep 13 10:16:00.609: //22119/00C0D2BD7300/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1323, Destination Call Id=22118)
002033: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1323, Call Id1=22118, Call Id2=22119
002034: Sep 13 10:16:00.609: //22118/00C0D2BD7300/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=22118
002035: Sep 13 10:16:00.613: //22119/00C0D2BD7300/CCAPI/cc_api_get_called_ccm_detected:
002036: Sep 13 10:16:00.621: //22118/00C0D2BD7300/CCAPI/cc_api_caps_ind:
Destination Interface=0x2B17C21C, Destination Call Id=22119, Source Call Id=22118,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
002037: Sep 13 10:16:00.621: //22118/00C0D2BD7300/CCAPI/cc_api_caps_ind:
002038: Sep 13 10:16:00.621: //22119/00C0D2BD7300/CCAPI/cc_api_caps_ack:
Destination Interface=0x2AD996F4, Destination Call Id=22118, Source Call Id=22119,
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
002039: Sep 13 10:16:00.621: //22118/00C0D2BD7300/CCAPI/cc_api_caps_ack:
Caps(Codec=gsmefr(0x0), Fax Rate=Invalid(0x0), Vad=Invalid(0x0),
Modem=OFF(0x0), Codec Bytes=0, Signal Type=0, Seq Num Start=0)
002040: Sep 13 10:16:00.625: //22118/00C0D2BD7300/CCAPI/cc_api_event_indication:
Event=167, Call Id=22118
002041: Sep 13 10:16:00.625: //22118/00C0D2BD7300/CCAPI/cc_api_event_indication:
002042: Sep 13 10:16:00.625: //22119/00C0D2BD7300/CCAPI/cc_api_event_indication:
Event=168, Call Id=22119
002043: Sep 13 10:16:00.625: //22119/00C0D2BD7300/CCAPI/cc_api_event_indication:
002044: Sep 13 10:16:00.629: //22118/00C0D2BD7300/CCAPI/cc_api_event_indication:
Event=168, Call Id=22118
002045: Sep 13 10:16:00.629: //22118/00C0D2BD7300/CCAPI/cc_api_event_indication:
002046: Sep 13 10:16:01.329: //22109/00D1B5B07000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server internal failure
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK314B262A;received=172.19.20.142;rport=50179
From: "Disbursement SME Desk-II" <sip:09612001122@172.16.252.12>;tag=13C1836C-241A
To: <sip:01891767357@172.16.252.12>;tag=as5b054678
Call-ID: 5E16A3A1-13B211EC-9555ABF4-A51D28B2@172.19.20.142
CSeq: 101 INVITE
Content-Length: 0
002047: Sep 13 10:16:01.329: //22109/00D1B5B07000/CCAPI/cc_api_call_disconnected:
Cause Value=41, Interface=0x2B17C21C, Call Id=22109
002048: Sep 13 10:16:01.329: //22109/00D1B5B07000/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
002049: Sep 13 10:16:01.329: //22108/00D1B5B07000/CCAPI/ccCallReleaseResources:
002050: Sep 13 10:16:01.329: //22109/00D1B5B07000/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=22109
002051: Sep 13 10:16:01.329: //22108/00D1B5B07000/CCAPI/ccConferenceDestroy:
Conference Id=0x131F, Tag=0x0
002052: Sep 13 10:16:01.329: //22108/00D1B5B07000/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x131F, Source Interface=0x2AD996F4, Source Call Id=22108,
Destination Call Id=22109, Disposition=0x0, Tag=0x0
002053: Sep 13 10:16:01.329: //22109/00D1B5B07000/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x131F, Source Interface=0x2B17C21C, Source Call Id=22109,
Destination Call Id=22108, Disposition=0x0, Tag=0x0
002054: Sep 13 10:16:01.329: //22108/00D1B5B07000/CCAPI/cc_generic_bridge_done:
002055: Sep 13 10:16:01.329: //22109/00D1B5B07000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01891767357@172.16.252.12:5060 SIP/2.0
Date: Mon, 13 Sep 2021 10:15:34 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
002056: Sep 13 10:16:01.329: //22109/00D1B5B07000/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
002057: Sep 13 10:16:01.329: //22109/00D1B5B07000/CCAPI/ccCallDisconnect:
Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
002058: Sep 13 10:16:01.333: //22109/00D1B5B07000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B17C21C, Tag=0x0, Call Id=22109,
Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
002059: Sep 13 10:16:01.333: //22109/00D1B5B07000/CCAPI/cc_api_call_disconnect_done:
002060: Sep 13 10:16:01.333: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002061: Sep 13 10:16:01.333: :cc_free_feature_vsa freeing 2BECB0F0
002062: Sep 13 10:16:01.333: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002063: Sep 13 10:16:01.333: vsacount in free is 24
002064: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=20, Params=0x306B8918, Progress Indication=NULL(0)
002065: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccCheckClipClir:
In: Calling Number=50452(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
002066: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccCheckClipClir:
Out: Calling Number=50452(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
002067: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccCallSetupRequest:
Destination Pattern=9T, Called Number=901891767357, Digit Strip=TRUE
002068: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccCallSetupRequest:
Calling Number=50452(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901891767357(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Disbursement SME Desk-II
Account Number=Disbursement SME Desk-II, Final Destination Flag=TRUE,
Guid=00D1B5B0-D335-F113-7000-7401AC160BBD, Outgoing Dial-peer=20
002069: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=Disbursement SME Desk-II
cisco-ani=50452
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=901891767357
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
002070: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x2B46C3A4, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=50452,(Calling Name=Disbursement SME Desk-II)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901891767357(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20, Call Count On=FALSE,
002071: Sep 13 10:16:01.333: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002072: Sep 13 10:16:01.333: :cc_get_feature_vsa malloc success
002073: Sep 13 10:16:01.333: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002074: Sep 13 10:16:01.333: cc_get_feature_vsa count is 25
002075: Sep 13 10:16:01.333: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002076: Sep 13 10:16:01.333: :FEATURE_VSA attributes are: feature_name:0,feature_time:736932088,feature_id:12770
002077: Sep 13 10:16:01.333: //22120/00D1B5B07000/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
002078: Sep 13 10:16:01.333: //22120/00D1B5B07000/CCAPI/ccCallSetContext:
Context=0x306B88C8
002079: Sep 13 10:16:01.333: //22108/00D1B5B07000/CCAPI/ccSaveDialpeerTag:
002080: Sep 13 10:16:01.333: //22120/00D1B5B07000/CCAPI/cc_api_call_proceeding:
Interface=0x2B46C3A4, Progress Indication=NULL(0)
002081: Sep 13 10:16:04.705: //22115/00857AB57200/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK314E1ADA;received=172.19.20.142;rport=50179
From: "IRMD DESK IX" <sip:09612001122@172.16.252.12>;tag=13C1A218-F0
To: <sip:01716171330@172.16.252.12>;tag=as688a8945
Call-ID: 62C55F07-13B211EC-955DABF4-A51D28B2@172.19.20.142
CSeq: 101 INVITE
Contact: <sip:01716171330@172.16.252.12:5060>
Require: timer
Content-Length: 277
v=0
o=root 1199910290 1199910290 IN IP4 172.16.252.12
t=0 0
m=audio 10434 RTP/AVP 0 8 101
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
002082: Sep 13 10:16:04.705: //22115/00857AB57200/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
002083: Sep 13 10:16:04.705: //22115/00857AB57200/CCAPI/cc_api_call_connected:
Interface=0x2B17C21C, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
002084: Sep 13 10:16:04.705: //22115/00857AB57200/CCAPI/cc_api_call_connected:
002085: Sep 13 10:16:04.709: //22114/00857AB57200/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
002086: Sep 13 10:16:04.709: //22115/00857AB57200/CCAPI/cc_api_get_called_ccm_detected:
002087: Sep 13 10:16:04.709: //22114/00857AB57200/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
002088: Sep 13 10:16:04.709: //22114/00857AB57200/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=22114
002089: Sep 13 10:16:04.709: //22115/00857AB57200/CCAPI/cc_api_get_called_ccm_detected:
002090: Sep 13 10:16:04.709: //22115/00857AB57200/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01716171330@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31512C7
Date: Mon, 13 Sep 2021 10:15:42 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Disposition: session;handling=required
Content-Length: 269
v=0
o=CiscoSystemsSIP-GW-UserAgent 589 8895 IN IP4 172.19.20.142
s=SIP Call
c=IN IP4 172.19.20.142
t=0 0
m=audio 30020 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=direction:active
002091: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_call_cut_progress:
Interface=0x2B46C3A4, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
002092: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_call_cut_progress:
002093: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
002094: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/ccCallCutProgress:
002095: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_get_called_ccm_detected:
002096: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/ccConferenceCreate:
(confID=0x2BEE9948, callID1=0x565C, gcid=0-0-0-0, tag=0x0)
002097: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/ccConferenceCreate:
(confID=0x2BEE9948, callID2=0x5668, gcid=0-0-0-0, tag=0x0)
002098: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/ccConferenceCreate:
Conference Id=0x2BEE9948, Call Id1=22108, Call Id2=22120, Tag=0x0
002099: Sep 13 10:16:05.141: //22108/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002100: Sep 13 10:16:05.141: cc_api_get_xcode_stream : 4702
002101: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/cc_api_bridge_done:
Conference Id=0x1324, Source Interface=0x2AD996F4, Source Call Id=22108,
Destination Call Id=22120, Disposition=0x0, Tag=0x0
002102: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_bridge_done:
Conference Id=0x1324, Source Interface=0x2B46C3A4, Source Call Id=22120,
Destination Call Id=22108, Disposition=0x0, Tag=0xFFFFFFFF
002103: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/cc_generic_bridge_done:
002104: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1324, Destination Call Id=22120)
002105: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1324, Destination Call Id=22108)
002106: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_caps_ind:
Destination Interface=0x2AD996F4, Destination Call Id=22108, Source Call Id=22120,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
002107: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_caps_ind:
002108: Sep 13 10:16:05.141: //22108/00D1B5B07000/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=22108
002109: Sep 13 10:16:05.141: //22120/00D1B5B07000/CCAPI/cc_api_get_called_ccm_detected:
002110: Sep 13 10:16:05.145: //22108/00D1B5B07000/CCAPI/cc_api_caps_ind:
Destination Interface=0x2B46C3A4, Destination Call Id=22120, Source Call Id=22108,
Caps(Codec=0x1, Fax Rate=0x80, Vad=0x1,
002111: Sep 13 10:16:05.145: //22108/00D1B5B07000/CCAPI/cc_api_caps_ind:
002112: Sep 13 10:16:05.145: //22108/00D1B5B07000/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_14400(0x80), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1436)
002113: Sep 13 10:16:05.145: //22120/00D1B5B07000/CCAPI/cc_api_caps_ack:
002114: Sep 13 10:16:05.145: //22108/00D1B5B07000/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1324, Call Id1=22108, Call Id2=22120
002115: Sep 13 10:16:05.145: //22120/00D1B5B07000/CCAPI/cc_api_voice_mode_event:
Call Id=22120
002116: Sep 13 10:16:05.145: //22120/00D1B5B07000/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x306B88C8)
002117: Sep 13 10:16:05.145: //22120/00D1B5B07000/CCAPI/cc_api_call_connected:
Interface=0x2B46C3A4, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
002118: Sep 13 10:16:05.145: //22120/00D1B5B07000/CCAPI/cc_api_call_connected:
002119: Sep 13 10:16:05.145: //22108/00D1B5B07000/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
002120: Sep 13 10:16:05.149: //22120/00D1B5B07000/CCAPI/cc_api_get_called_ccm_detected:
002121: Sep 13 10:16:05.149: //22108/00D1B5B07000/CCAPI/ccCallConnect:
002122: Sep 13 10:16:05.149: //22108/00D1B5B07000/CCAPI/ccCallNotify:
002123: Sep 13 10:16:05.149: //22120/00D1B5B07000/CCAPI/cc_api_get_called_ccm_detected:
002124: Sep 13 10:16:06.213: //22106/800DECAE6F00/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK314A1A34;received=172.19.20.142;rport=50179
From: "Retail Collection III" <sip:09612001122@172.16.252.12>;tag=13C176D8-1063
To: <sip:01871653664@172.16.252.12>;tag=as2f515c36
Call-ID: 5C2BEB87-13B211EC-9551ABF4-A51D28B2@172.19.20.142
CSeq: 101 INVITE
Contact: <sip:01871653664@172.16.252.12:5060>
Diversion: <sip:01871653664@172.16.252.12>;reason=unconditional
Content-Length: 0
002125: Sep 13 10:16:06.213: //22106/800DECAE6F00/CCAPI/cc_api_call_cut_progress:
Cause Value=0
002126: Sep 13 10:16:06.213: //22106/800DECAE6F00/CCAPI/cc_api_call_cut_progress:
002127: Sep 13 10:16:06.217: //22105/800DECAE6F00/CCAPI/ccCallProgIndProgress:
002128: Sep 13 10:16:06.217: //22106/800DECAE6F00/CCAPI/cc_api_get_called_ccm_detected:
002129: Sep 13 10:16:06.217: //22106/800DECAE6F00/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
002130: Sep 13 10:16:06.217: //22106/800DECAE6F00/CCAPI/cc_api_call_disconnected:
Cause Value=17, Interface=0x2B17C21C, Call Id=22106
002131: Sep 13 10:16:06.217: //22106/800DECAE6F00/CCAPI/cc_api_call_disconnected:
002132: Sep 13 10:16:06.217: //22105/800DECAE6F00/CCAPI/ccCallReleaseResources:
002133: Sep 13 10:16:06.217: //22106/800DECAE6F00/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=22106
002134: Sep 13 10:16:06.217: //22105/800DECAE6F00/CCAPI/ccConferenceDestroy:
Conference Id=0x1320, Tag=0x0
002135: Sep 13 10:16:06.217: //22105/800DECAE6F00/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x1320, Source Interface=0x2AD996F4, Source Call Id=22105,
Destination Call Id=22106, Disposition=0x0, Tag=0x0
002136: Sep 13 10:16:06.217: //22106/800DECAE6F00/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x1320, Source Interface=0x2B17C21C, Source Call Id=22106,
Destination Call Id=22105, Disposition=0x0, Tag=0x0
002137: Sep 13 10:16:06.217: //22105/800DECAE6F00/CCAPI/cc_generic_bridge_done:
002138: Sep 13 10:16:06.221: //22106/800DECAE6F00/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01871653664@172.16.252.12:5060 SIP/2.0
Date: Mon, 13 Sep 2021 10:15:31 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
002139: Sep 13 10:16:06.221: //22106/800DECAE6F00/CCAPI/ccCallDisconnect:
002140: Sep 13 10:16:06.221: //22106/800DECAE6F00/CCAPI/ccCallDisconnect:
002141: Sep 13 10:16:06.221: //22106/800DECAE6F00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B17C21C, Tag=0x0, Call Id=22106,
002142: Sep 13 10:16:06.221: //22106/800DECAE6F00/CCAPI/cc_api_call_disconnect_done:
002143: Sep 13 10:16:06.221: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002144: Sep 13 10:16:06.221: :cc_free_feature_vsa freeing 2BECA750
002145: Sep 13 10:16:06.221: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002146: Sep 13 10:16:06.221: vsacount in free is 24
002147: Sep 13 10:16:06.221: //22105/800DECAE6F00/CCAPI/ccCallDisconnect:
002148: Sep 13 10:16:06.221: //22105/800DECAE6F00/CCAPI/ccCallDisconnect:
002149: Sep 13 10:16:06.221: //22105/800DECAE6F00/CCAPI/cc_api_get_transfer_info:
002150: Sep 13 10:16:06.221: //22105/800DECAE6F00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2AD996F4, Tag=0x0, Call Id=22105,
002151: Sep 13 10:16:06.221: //22105/800DECAE6F00/CCAPI/cc_api_call_disconnect_done:
002152: Sep 13 10:16:06.221: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002153: Sep 13 10:16:06.221: :cc_free_feature_vsa freeing 2BECBFD0
002154: Sep 13 10:16:06.221: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002155: Sep 13 10:16:06.221: vsacount in free is 23
002156: Sep 13 10:16:06.597: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
002157: Sep 13 10:16:06.597: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002158: Sep 13 10:16:06.597: :cc_get_feature_vsa malloc success
002159: Sep 13 10:16:06.597: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002160: Sep 13 10:16:06.601: cc_get_feature_vsa count is 24
002161: Sep 13 10:16:06.601: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002162: Sep 13 10:16:06.601: :FEATURE_VSA attributes are: feature_name:0,feature_time:736935896,feature_id:12771
002163: Sep 13 10:16:06.601: //22121/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
002164: Sep 13 10:16:06.601: //22121/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x3057EE20
002165: Sep 13 10:16:06.601: //22121/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Connection Handle=0
002166: Sep 13 10:16:06.601: //22121/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
002167: Sep 13 10:16:06.609: //22121/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
002168: Sep 13 10:16:06.609: //22121/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
002169: Sep 13 10:16:06.609: //22121/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30F94910, Tag=0x0, Call Id=22121,
002170: Sep 13 10:16:06.609: //22121/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
002171: Sep 13 10:16:06.609: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002172: Sep 13 10:16:06.609: :cc_free_feature_vsa freeing 2BECBFD0
002173: Sep 13 10:16:06.609: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002174: Sep 13 10:16:06.609: vsacount in free is 23
002175: Sep 13 10:16:06.617: //-1/00A1C8C37400/CCAPI/cc_api_display_ie_subfields:
cisco-username=NOC 3
cisco-ani=50158
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=901716906564
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
002176: Sep 13 10:16:06.617: //-1/00A1C8C37400/CCAPI/cc_api_call_setup_ind_common:
Calling Number=50158,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901716906564(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=22122
002177: Sep 13 10:16:06.617: //-1/00A1C8C37400/CCAPI/ccCheckClipClir:
In: Calling Number=50158(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
002178: Sep 13 10:16:06.617: //-1/00A1C8C37400/CCAPI/ccCheckClipClir:
Out: Calling Number=50158(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
002179: Sep 13 10:16:06.617: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002180: Sep 13 10:16:06.617: :cc_get_feature_vsa malloc success
002181: Sep 13 10:16:06.617: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002182: Sep 13 10:16:06.617: cc_get_feature_vsa count is 24
002183: Sep 13 10:16:06.617: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002184: Sep 13 10:16:06.617: :FEATURE_VSA attributes are: feature_name:0,feature_time:736935896,feature_id:12772
002185: Sep 13 10:16:06.617: //22122/00A1C8C37400/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=50158(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901716906564(TON=Unknown, NPI=Unknown))
002186: Sep 13 10:16:06.617: //22122/00A1C8C37400/CCAPI/cc_process_call_setup_ind:
Event=0x2B4306B8
002187: Sep 13 10:16:06.617: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 901716906564
002188: Sep 13 10:16:06.617: //22122/00A1C8C37400/CCAPI/ccCallSetContext:
Context=0x2BECF61C
002189: Sep 13 10:16:06.617: //22122/00A1C8C37400/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 22122 with tag 4 to app "_ManagedAppProcess_Default"
002190: Sep 13 10:16:06.617: //22122/00A1C8C37400/CCAPI/ccCallProceeding:
002191: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2, Params=0x2BEDFBA4, Progress Indication=NULL(0)
002192: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccCheckClipClir:
002193: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccCheckClipClir:
002194: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccCallSetupRequest:
Destination Pattern=9T, Called Number=01716906564, Digit Strip=FALSE
002195: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccCallSetupRequest:
Called Number=01716906564(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=NOC 3
Account Number=NOC 3, Final Destination Flag=TRUE,
Guid=00A1C8C3-F335-F113-7400-7801AC160B2D, Outgoing Dial-peer=2
002196: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01716906564
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
002197: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccIFCallSetupRequestPrivate:
Call Params(Calling Number=09612001122,(Calling Name=NOC 3)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01716906564(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
002198: Sep 13 10:16:06.621: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002199: Sep 13 10:16:06.621: :cc_get_feature_vsa malloc success
002200: Sep 13 10:16:06.621: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002201: Sep 13 10:16:06.621: cc_get_feature_vsa count is 25
002202: Sep 13 10:16:06.621: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002203: Sep 13 10:16:06.621: :FEATURE_VSA attributes are: feature_name:0,feature_time:736929624,feature_id:12773
002204: Sep 13 10:16:06.621: //22123/00A1C8C37400/CCAPI/ccIFCallSetupRequestPrivate:
002205: Sep 13 10:16:06.621: //22123/00A1C8C37400/CCAPI/ccCallSetContext:
Context=0x2BEDFB54
002206: Sep 13 10:16:06.621: //22122/00A1C8C37400/CCAPI/ccSaveDialpeerTag:
002207: Sep 13 10:16:06.621: //22123/00A1C8C37400/CCAPI/cc_api_call_proceeding:
002208: Sep 13 10:16:06.625: //22123/00A1C8C37400/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:01716906564@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315221D1
From: "NOC 3" <sip:09612001122@172.16.252.12>;tag=13C200C4-303
To: <sip:01716906564@172.16.252.12>
Date: Mon, 13 Sep 2021 10:16:06 GMT
Call-ID: 71377D9A-13B211EC-9567ABF4-A51D28B2@172.19.20.142
Min-SE: 1800
Cisco-Guid: 0010602691-4080398611-1946187777-2887125805
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1631528166
Expires: 180
Content-Length: 0
002209: Sep 13 10:16:06.633: //22123/00A1C8C37400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315221D1;received=172.19.20.142;rport=50179
CSeq: 101 INVITE
Contact: <sip:01716906564@172.16.252.12:5060>
Content-Length: 0
002210: Sep 13 10:16:07.493: //22123/00A1C8C37400/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:01716906564@172.16.252.12>;tag=as3cc31a36
CSeq: 101 INVITE
Require: timer
Content-Length: 277
v=0
o=root 1710667973 1710667973 IN IP4 172.16.252.12
t=0 0
m=audio 14992 RTP/AVP 0 8 101
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
002211: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_event_indication:
Event=91, Call Id=22123
002212: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_event_indication:
002213: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=22123,
002214: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_caps_ind:
002215: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_call_cut_progress:
Cause Value=0
002216: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_call_cut_progress:
002217: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/ccCallCutProgress:
002218: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/ccCallCutProgress:
002219: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_get_called_ccm_detected:
002220: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/ccConferenceCreate:
(confID=0x2BEE9708, callID1=0x566A, gcid=0-0-0-0, tag=0x0)
002221: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/ccConferenceCreate:
(confID=0x2BEE9708, callID2=0x566B, gcid=0-0-0-0, tag=0x0)
002222: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/ccConferenceCreate:
Conference Id=0x2BEE9708, Call Id1=22122, Call Id2=22123, Tag=0x0
002223: Sep 13 10:16:07.497: //22122/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002224: Sep 13 10:16:07.497: cc_api_get_xcode_stream : 4702
002225: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/cc_api_bridge_done:
Conference Id=0x1325, Source Interface=0x2AD996F4, Source Call Id=22122,
Destination Call Id=22123, Disposition=0x0, Tag=0x0
002226: Sep 13 10:16:07.497: //22123/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002227: Sep 13 10:16:07.497: cc_api_get_xcode_stream : 4702
002228: Sep 13 10:16:07.497: //22123/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002229: Sep 13 10:16:07.497: cc_api_get_xcode_stream : 4702
002230: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/cc_api_bridge_done:
Conference Id=0x1325, Source Interface=0x2B17C21C, Source Call Id=22123,
Destination Call Id=22122, Disposition=0x0, Tag=0x0
002231: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/cc_generic_bridge_done:
002232: Sep 13 10:16:07.497: //22122/00A1C8C37400/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1325, Destination Call Id=22123)
002233: Sep 13 10:16:07.497: //22123/00A1C8C37400/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1325, Destination Call Id=22122)
002234: Sep 13 10:16:07.501: //22122/00A1C8C37400/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1325, Call Id1=22122, Call Id2=22123
002235: Sep 13 10:16:07.501: //22122/00A1C8C37400/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=22122
002236: Sep 13 10:16:07.501: //22123/00A1C8C37400/CCAPI/cc_api_get_called_ccm_detected:
002237: Sep 13 10:16:07.513: //22122/00A1C8C37400/CCAPI/cc_api_caps_ind:
Destination Interface=0x2B17C21C, Destination Call Id=22123, Source Call Id=22122,
002238: Sep 13 10:16:07.513: //22122/00A1C8C37400/CCAPI/cc_api_caps_ind:
002239: Sep 13 10:16:07.513: //22123/00A1C8C37400/CCAPI/cc_api_caps_ack:
Destination Interface=0x2AD996F4, Destination Call Id=22122, Source Call Id=22123,
002240: Sep 13 10:16:07.513: //22122/00A1C8C37400/CCAPI/cc_api_caps_ack:
002241: Sep 13 10:16:07.517: //22122/00A1C8C37400/CCAPI/cc_api_event_indication:
Event=167, Call Id=22122
002242: Sep 13 10:16:07.517: //22122/00A1C8C37400/CCAPI/cc_api_event_indication:
002243: Sep 13 10:16:07.517: //22123/00A1C8C37400/CCAPI/cc_api_event_indication:
Event=168, Call Id=22123
002244: Sep 13 10:16:07.517: //22123/00A1C8C37400/CCAPI/cc_api_event_indication:
002245: Sep 13 10:16:07.521: //22122/00A1C8C37400/CCAPI/cc_api_event_indication:
Event=168, Call Id=22122
002246: Sep 13 10:16:07.521: //22122/00A1C8C37400/CCAPI/cc_api_event_indication:
002247: Sep 13 10:16:15.781: //22096/804B00A36D00/CCAPI/cc_api_caps_ind:
Destination Interface=0x2B17C21C, Destination Call Id=22097, Source Call Id=22096,
Caps(Codec=0x0, Fax Rate=0x2, Vad=0x2,
002248: Sep 13 10:16:15.781: //22096/804B00A36D00/CCAPI/cc_api_caps_ind:
SIP: (22097) Group (a= group line) attribute, level 65535 instance 1 not found.
002249: Sep 13 10:16:15.785: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:01967315727@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK3153222A
From: "Disbursement SME Desk-II" <sip:09612001122@172.16.252.12>;tag=13C12754-1AF9
To: <sip:01967315727@172.16.252.12>;tag=as495dcd17
Date: Mon, 13 Sep 2021 10:16:15 GMT
Call-ID: 5009D5DE-13B211EC-9546ABF4-A51D28B2@172.19.20.142
Min-SE: 1800
Cisco-Guid: 2152399011-3157651731-1828745473-2887125949
CSeq: 105 INVITE
Max-Forwards: 70
Timestamp: 1631528175
Expires: 180
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 7513 1729 IN IP4 172.19.20.142
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 32130 RTP/AVP 0 101
c=IN IP4 0.0.0.0
a=fmtp:101 0-16
a=inactive
002250: Sep 13 10:16:15.789: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK3153222A;received=172.19.20.142;rport=50179
CSeq: 105 INVITE
Contact: <sip:01967315727@172.16.252.12:5060>
Content-Length: 0
002251: Sep 13 10:16:15.789: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 INVITE
Require: timer
Content-Length: 251
v=0
o=root 123620981 123620985 IN IP4 172.16.252.12
t=0 0
m=audio 12306 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=inactive
002252: Sep 13 10:16:15.793: //22097/804B00A36D00/CCAPI/cc_api_caps_ack:
Destination Interface=0x2AD996F4, Destination Call Id=22096, Source Call Id=22097,
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=0)
002253: Sep 13 10:16:15.793: //22097/804B00A36D00/CCAPI/cc_api_call_suspend_ack_ind:
Interface=0x2B17C21C, Call Id=22097
002254: Sep 13 10:16:15.793: //22096/804B00A36D00/CCAPI/ccCallSuspendAck:
Call Id=22096
002255: Sep 13 10:16:15.793: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01967315727@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31541FB9
Max-Forwards: 70
CSeq: 105 ACK
Content-Length: 0
002256: Sep 13 10:16:15.973: //22108/00D1B5B07000/CCAPI/cc_api_call_userinfo:
Interface=0x2AD996F4, Signal Indication=TONES OFF(63)
002257: Sep 13 10:16:15.973: //22120/00D1B5B07000/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=22120
002258: Sep 13 10:16:15.973: //22108/00D1B5B07000/CCAPI/cc_api_call_userinfo:
002259: Sep 13 10:16:15.973: //22096/804B00A36D00/CCAPI/cc_api_call_userinfo:
002260: Sep 13 10:16:15.973: //22108/00D1B5B07000/CCAPI/cc_api_set_called_ccm_detected:
CallInfo(called ccm detected=TRUE ccmVersion 3)
002261: Sep 13 10:16:15.973: //22108/00D1B5B07000/CCAPI/cc_api_call_notify:
Data Bitmask=0x5, Interface=0x2AD996F4, Call Id=22108
002262: Sep 13 10:16:15.973: //22096/804B00A36D00/CCAPI/cc_api_call_userinfo:
002263: Sep 13 10:16:15.973: //22096/804B00A36D00/CCAPI/cc_api_set_called_ccm_detected:
002264: Sep 13 10:16:15.973: //22096/804B00A36D00/CCAPI/cc_api_call_notify:
Data Bitmask=0x5, Interface=0x2AD996F4, Call Id=22096
002265: Sep 13 10:16:15.973: //22120/00D1B5B07000/CCAPI/ccGenerateToneInfo:
002266: Sep 13 10:16:15.973: //22097/804B00A36D00/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=22097
002267: Sep 13 10:16:15.977: //22096/804B00A36D00/CCAPI/cc_api_call_userinfo:
002268: Sep 13 10:16:15.977: //22096/804B00A36D00/CCAPI/cc_api_set_called_ccm_detected:
002269: Sep 13 10:16:15.977: //22096/804B00A36D00/CCAPI/cc_api_call_notify:
002270: Sep 13 10:16:15.977: //22120/00D1B5B07000/CCAPI/ccCallNotify:
Data Bitmask=0x5, Call Id=22120
002271: Sep 13 10:16:15.977: //22096/804B00A36D00/CCAPI/cc_api_caps_ind:
002272: Sep 13 10:16:15.977: //22096/804B00A36D00/CCAPI/cc_api_caps_ind:
002273: Sep 13 10:16:15.977: //22097/804B00A36D00/SIP/Error/sipSPIUpdateSrcSdpFixedPart: owner_sessionid is already their OR src_sdp
is corrupted
002274: Sep 13 10:16:15.981: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315524EF
Min-SE: 1800
CSeq: 106 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 7513 1730 IN IP4 172.19.20.142
s=SIP Call
t=0 0
a=inactive
a=fmtp:101 0-16
002275: Sep 13 10:16:15.981: //22097/804B00A36D00/CCAPI/ccGenerateToneInfo:
002276: Sep 13 10:16:15.981: //22097/804B00A36D00/CCAPI/ccCallNotify:
Data Bitmask=0x5, Call Id=22097
002277: Sep 13 10:16:15.981: //22097/804B00A36D00/CCAPI/ccGenerateToneInfo:
002278: Sep 13 10:16:15.981: //22097/804B00A36D00/CCAPI/ccCallNotify:
002279: Sep 13 10:16:15.985: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315524EF;received=172.19.20.142;rport=50179
CSeq: 106 INVITE
Content-Length: 0
002280: Sep 13 10:16:15.985: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 INVITE
Require: timer
Content-Length: 251
v=0
o=root 123620981 123620986 IN IP4 172.16.252.12
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=inactive
002281: Sep 13 10:16:15.989: //22097/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002282: Sep 13 10:16:15.989: cc_api_get_xcode_stream : 4702
002283: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_caps_ind:
002284: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_caps_ind:
002285: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
Event=91, Call Id=22097
002286: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
002287: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_caps_ack:
002288: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
Event=167, Call Id=22097
002289: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
002290: Sep 13 10:16:15.989: //22097/804B00A36D00/CCAPI/cc_api_call_suspend_ack_ind:
002291: Sep 13 10:16:15.989: //22096/804B00A36D00/CCAPI/ccCallSuspendAck:
Call Id=22096
002292: Sep 13 10:16:15.993: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31569A8
Max-Forwards: 70
CSeq: 106 ACK
Content-Length: 0
002293: Sep 13 10:16:15.993: //22096/804B00A36D00/CCAPI/cc_api_caps_ack:
002294: Sep 13 10:16:16.001: //22096/804B00A36D00/CCAPI/cc_api_caps_ind:
002295: Sep 13 10:16:16.001: //22096/804B00A36D00/CCAPI/cc_api_caps_ind:
002296: Sep 13 10:16:16.001: //22097/804B00A36D00/CCAPI/cc_api_caps_ack:
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=3895)
002297: Sep 13 10:16:16.005: //22096/804B00A36D00/CCAPI/cc_api_event_indication:
Event=167, Call Id=22096
002298: Sep 13 10:16:16.005: //22096/804B00A36D00/CCAPI/cc_api_event_indication:
002299: Sep 13 10:16:16.005: //22108/00D1B5B07000/CCAPI/cc_api_caps_ind:
002300: Sep 13 10:16:16.005: //22108/00D1B5B07000/CCAPI/cc_api_caps_ind:
002301: Sep 13 10:16:16.005: //22108/00D1B5B07000/CCAPI/cc_api_caps_ack:
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1968)
002302: Sep 13 10:16:16.005: //22120/00D1B5B07000/CCAPI/cc_api_caps_ack:
002303: Sep 13 10:16:16.005: //22120/00D1B5B07000/CCAPI/cc_api_voice_mode_event:
Call Id=22120
002304: Sep 13 10:16:16.005: //22120/00D1B5B07000/CCAPI/cc_api_voice_mode_event:
002305: Sep 13 10:16:16.005: //22096/804B00A36D00/CCAPI/cc_api_event_indication:
Event=168, Call Id=22096
002306: Sep 13 10:16:16.005: //22096/804B00A36D00/CCAPI/cc_api_event_indication:
002307: Sep 13 10:16:16.009: //22097/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002308: Sep 13 10:16:16.009: cc_api_get_xcode_stream : 4702
002309: Sep 13 10:16:16.017: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31571F9
Date: Mon, 13 Sep 2021 10:16:16 GMT
Min-SE: 1800
CSeq: 107 INVITE
Max-Forwards: 70
Timestamp: 1631528176
Expires: 180
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 7513 1731 IN IP4 172.19.20.142
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
002310: Sep 13 10:16:16.021: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK31571F9;received=172.19.20.142;rport=50179
CSeq: 107 INVITE
Content-Length: 0
002311: Sep 13 10:16:16.021: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 107 INVITE
Require: timer
Content-Length: 251
v=0
o=root 123620981 123620987 IN IP4 172.16.252.12
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
002312: Sep 13 10:16:16.021: //22097/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002313: Sep 13 10:16:16.021: cc_api_get_xcode_stream : 4702
002314: Sep 13 10:16:16.021: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
Event=168, Call Id=22097
002315: Sep 13 10:16:16.021: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
002316: Sep 13 10:16:16.021: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
002317: Sep 13 10:16:16.021: //22097/804B00A36D00/CCAPI/cc_api_event_indication:
002318: Sep 13 10:16:16.021: //22096/804B00A36D00/CCAPI/cc_api_event_indication:
002319: Sep 13 10:16:16.021: //22096/804B00A36D00/CCAPI/cc_api_event_indication:
002320: Sep 13 10:16:16.025: //22097/804B00A36D00/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK3158130A
Max-Forwards: 70
CSeq: 107 ACK
Content-Length: 0
002321: Sep 13 10:16:16.881: //22119/00C0D2BD7300/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Content-Length: 275
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
002322: Sep 13 10:16:16.881: //22119/00C0D2BD7300/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
002323: Sep 13 10:16:16.881: //22119/00C0D2BD7300/CCAPI/cc_api_call_connected:
Connection Handle=0
002324: Sep 13 10:16:16.881: //22119/00C0D2BD7300/CCAPI/cc_api_call_connected:
002325: Sep 13 10:16:16.885: //22118/00C0D2BD7300/CCAPI/ccCallConnect:
002326: Sep 13 10:16:16.885: //22119/00C0D2BD7300/CCAPI/cc_api_get_called_ccm_detected:
002327: Sep 13 10:16:16.885: //22118/00C0D2BD7300/CCAPI/ccCallConnect:
002328: Sep 13 10:16:16.885: //22118/00C0D2BD7300/CCAPI/ccCallNotify:
002329: Sep 13 10:16:16.885: //22119/00C0D2BD7300/CCAPI/cc_api_get_called_ccm_detected:
002330: Sep 13 10:16:16.885: //22119/00C0D2BD7300/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01725802102@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK3159F71
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 270
v=0
o=CiscoSystemsSIP-GW-UserAgent 7090 5531 IN IP4 172.19.20.142
s=SIP Call
t=0 0
m=audio 29302 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=direction:active
002331: Sep 13 10:16:21.893: //22123/00A1C8C37400/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Content-Length: 277
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
002332: Sep 13 10:16:21.897: //22123/00A1C8C37400/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
002333: Sep 13 10:16:21.897: //22123/00A1C8C37400/CCAPI/cc_api_call_connected:
Connection Handle=0
002334: Sep 13 10:16:21.897: //22123/00A1C8C37400/CCAPI/cc_api_call_connected:
002335: Sep 13 10:16:21.897: //22122/00A1C8C37400/CCAPI/ccCallConnect:
002336: Sep 13 10:16:21.897: //22123/00A1C8C37400/CCAPI/cc_api_get_called_ccm_detected:
002337: Sep 13 10:16:21.897: //22122/00A1C8C37400/CCAPI/ccCallConnect:
002338: Sep 13 10:16:21.901: //22122/00A1C8C37400/CCAPI/ccCallNotify:
002339: Sep 13 10:16:21.901: //22123/00A1C8C37400/CCAPI/cc_api_get_called_ccm_detected:
002340: Sep 13 10:16:21.901: //22123/00A1C8C37400/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:01716906564@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315A18FD
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 270
v=0
o=CiscoSystemsSIP-GW-UserAgent 4201 3292 IN IP4 172.19.20.142
s=SIP Call
t=0 0
m=audio 20478 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=direction:active
002341: Sep 13 10:16:22.857: //22085/809AF7896A00/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 6 to dstCallId 0x5644
002342: Sep 13 10:16:22.857: //22085/809AF7896A00/CCAPI/cc_relay_digit_begin_for_3way_conference:
002343: Sep 13 10:16:22.937: //22085/809AF7896A00/CCAPI/cc_api_call_digit_end:
002344: Sep 13 10:16:22.937: //22085/809AF7896A00/CCAPI/cc_relay_digit_end_for_3way_conference:
002345: Sep 13 10:16:24.849: //22068/80460D5F6500/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit A to dstCallId 0x5633
002346: Sep 13 10:16:24.849: //22068/80460D5F6500/CCAPI/cc_relay_digit_begin_for_3way_conference:
002347: Sep 13 10:16:24.929: //22068/80460D5F6500/CCAPI/cc_api_call_digit_end:
002348: Sep 13 10:16:24.929: //22068/80460D5F6500/CCAPI/cc_relay_digit_end_for_3way_conference:
002349: Sep 13 10:16:33.285: //22093/801ECFA16C00/CCAPI/cc_api_call_digit_begin:
002350: Sep 13 10:16:33.285: //22093/801ECFA16C00/CCAPI/cc_relay_digit_begin_for_3way_conference:
002351: Sep 13 10:16:33.405: //22093/801ECFA16C00/CCAPI/cc_api_call_digit_end:
002352: Sep 13 10:16:33.405: //22093/801ECFA16C00/CCAPI/cc_relay_digit_end_for_3way_conference:
002353: Sep 13 10:16:33.621: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
002354: Sep 13 10:16:33.621: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002355: Sep 13 10:16:33.621: :cc_get_feature_vsa malloc success
002356: Sep 13 10:16:33.621: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002357: Sep 13 10:16:33.621: cc_get_feature_vsa count is 26
002358: Sep 13 10:16:33.621: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002359: Sep 13 10:16:33.621: :FEATURE_VSA attributes are: feature_name:0,feature_time:736928728,feature_id:12774
002360: Sep 13 10:16:33.621: //22124/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
002361: Sep 13 10:16:33.621: //22124/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x3057E800
002362: Sep 13 10:16:33.621: //22124/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Connection Handle=0
002363: Sep 13 10:16:33.621: //22124/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
002364: Sep 13 10:16:33.633: //22124/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
002365: Sep 13 10:16:33.633: //22124/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
002366: Sep 13 10:16:33.633: //22124/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x30F94910, Tag=0x0, Call Id=22124,
002367: Sep 13 10:16:33.633: //22124/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
002368: Sep 13 10:16:33.633: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002369: Sep 13 10:16:33.633: :cc_free_feature_vsa freeing 2BECA3D0
002370: Sep 13 10:16:33.633: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002371: Sep 13 10:16:33.633: vsacount in free is 25
002372: Sep 13 10:16:33.637: //-1/8080E0D37500/CCAPI/cc_api_display_ie_subfields:
cisco-username=In charge Monitoring Unit
cisco-ani=50441
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=901840708082
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
002373: Sep 13 10:16:33.637: //-1/8080E0D37500/CCAPI/cc_api_call_setup_ind_common:
Calling Number=50441,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901840708082(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=22125
002374: Sep 13 10:16:33.637: //-1/8080E0D37500/CCAPI/ccCheckClipClir:
In: Calling Number=50441(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
002375: Sep 13 10:16:33.637: //-1/8080E0D37500/CCAPI/ccCheckClipClir:
Out: Calling Number=50441(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
002376: Sep 13 10:16:33.637: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002377: Sep 13 10:16:33.637: :cc_get_feature_vsa malloc success
002378: Sep 13 10:16:33.637: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002379: Sep 13 10:16:33.641: cc_get_feature_vsa count is 26
002380: Sep 13 10:16:33.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002381: Sep 13 10:16:33.641: :FEATURE_VSA attributes are: feature_name:0,feature_time:736928728,feature_id:12775
002382: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=50441(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=901840708082(TON=Unknown, NPI=Unknown))
002383: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/cc_process_call_setup_ind:
Event=0x2B4306B8
002384: Sep 13 10:16:33.641: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 901840708082
002385: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCallSetContext:
Context=0x2BED467C
002386: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 22125 with tag 4 to app "_ManagedAppProcess_Default"
002387: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCallProceeding:
002388: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2, Params=0x306A6FC8, Progress Indication=NULL(0)
002389: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCheckClipClir:
002390: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCheckClipClir:
002391: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCallSetupRequest:
Destination Pattern=9T, Called Number=01840708082, Digit Strip=FALSE
002392: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccCallSetupRequest:
Called Number=01840708082(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=In charge Monitoring Unit
Account Number=In charge Monitoring Unit, Final Destination Flag=TRUE,
Guid=8080E0D3-0E36-F113-7500-7901AC160BC5, Outgoing Dial-peer=2
002393: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=01840708082
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
002394: Sep 13 10:16:33.641: //22125/8080E0D37500/CCAPI/ccIFCallSetupRequestPrivate:
Call Params(Calling Number=09612001122,(Calling Name=In charge Monitoring Unit)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=01840708082(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
002395: Sep 13 10:16:33.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002396: Sep 13 10:16:33.641: :cc_get_feature_vsa malloc success
002397: Sep 13 10:16:33.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002398: Sep 13 10:16:33.641: cc_get_feature_vsa count is 27
002399: Sep 13 10:16:33.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002400: Sep 13 10:16:33.641: :FEATURE_VSA attributes are: feature_name:0,feature_time:736931192,feature_id:12776
002401: Sep 13 10:16:33.641: //22126/8080E0D37500/CCAPI/ccIFCallSetupRequestPrivate:
002402: Sep 13 10:16:33.641: //22126/8080E0D37500/CCAPI/ccCallSetContext:
Context=0x306A6F78
002403: Sep 13 10:16:33.645: //22125/8080E0D37500/CCAPI/ccSaveDialpeerTag:
002404: Sep 13 10:16:33.645: //22126/8080E0D37500/CCAPI/cc_api_call_proceeding:
002405: Sep 13 10:16:33.645: //22126/8080E0D37500/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:01840708082@172.16.252.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315B2295
From: "In charge Monitoring Unit" <sip:09612001122@172.16.252.12>;tag=13C26A54-A4
Date: Mon, 13 Sep 2021 10:16:33 GMT
Call-ID: 8153060A-13B211EC-956BABF4-A51D28B2@172.19.20.142
Min-SE: 1800
Cisco-Guid: 2155929811-0238481683-1962965249-2887125957
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1631528193
Expires: 180
Content-Length: 0
002406: Sep 13 10:16:33.653: //22126/8080E0D37500/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.19.20.142:5060;branch=z9hG4bK315B2295;received=172.19.20.142;rport=50179
CSeq: 101 INVITE
Md.soriful
Problem is solved. CUCM to VG trunk was H323 but VG to ITSP was SIP so the ring-back tone problem has gotten.
Old Call Flow: IP Phone > CUCM > H323 > CUBE > SIP > ITSP
New Call Flow: IP Phone > CUCM > SIP > CUBE > SIP > ITSP
5 Replies 5
TONY SMITH
What is your system?  I can see you have an IOS voice gateway, but is that talking to Callmanager or what?
You have several calls in that debug with a number of (presumably unrelated) errors.  If your problem call is the one from To 01716906564 from 09612001122 then it looks like you are not sending a response to the 183 message.  The sequence I see is ...
Send Invite, delayed offer with no SDP
Receive Trying
Receive 183 Session Progress (with SDP)
If I remember correctly it should be a PRAK sent after receiving the 183, containing your SDP so that the audio path can complete.  I won't swear to that as all the traces I have to hand have an EO Invite.  It may actually be an OK referencing the 183 message.  But you need something, the 183 message says they want to send inband audio (the ringing tone) but at that stage you have not sent any SDP so they don't know where to send the audio or what codec or anything.
For comparision see the final 200 OK
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Require: timer
Content-Length: 277
v=0
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=maxptime:150
a=sendrecv
It may make sense to change your gateway to Early Offer if that's supported by the provider.  Add " voice-class sip early-offer forced" to the outbound Dial Peer.
Md.soriful
Hi Sir,
I have Added " voice-class sip early-offer forced" to the outbound Dial Peer. But the problem is not solved.
Can you post up your full configuration?  Also the CUCM trunk configuration.  And a new debug for an outgoing call.  Ideally could you attach these as text files, that's easier for us that a five mile long post with the debugs inline.  At this stage we just need "debug ccsip mess"
Md.soriful
aishwarya.singh
Please check SIP signalling and paste it here . Check if you have 180 ringing ?
