Ringing instead of Announcment for Mobile calls
Nashaatmusa
Hello Experts,
I have the following problem in my system that is kind of new to me, when i call a closed mobile phone from an IP phone that is registered to CUCM
i hear Ring back tone instead of Announcement that informs me that the mobile is closed, this is causing a lot of problems to the users as they don't know that the status of the phone is closed.
- the issue happens to all Cisco ip phone models.
the following call flow is implemented :
IP Phone ---- SCCP ---- CUCM ----- SIP ------ CUBE ------------ SIP ------------- Provider.
Collected CCSIP messages debugs from the gateway, please see the following
Invite Received from Call Manager,
102406: *Jun 22 12:46:31.463: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5555962788883597@172.31.21.3:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.170.31:5060;branch=z9hG4bK607d9458500dcc
From: "t" <sip:0785505500@192.168.170.31>;tag=aeccc64a-4d9a-49ae-a58f-d89f9e1e529a-57073288
To: <sip:5555962788883597@172.31.21.3>
Date: Mon, 22 Jun 2015 07:18:41 GMT
Call-ID: e75b2400-5871b6d1-29fd2c-1faaa8c0@192.168.170.31
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Contact: <sip:0785505500@192.168.170.31:5060;transport=tcp>
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:192.168.170.31:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3881509888-0000065536-0001639187-0531278016
Session-Expires:  1800
P-Asserted-Identity: "t" <sip:0785505500@192.168.170.31>
Remote-Party-ID: "t" <sip:0785505500@192.168.170.31>;party=calling;screen=yes;privacy=off
Max-Forwards: 70
Content-Length: 0
Gateway Sent Invite message to provider.
102407: *Jun 22 12:46:31.491: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5555962788883597@212.118.26.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.230.2:5060;branch=z9hG4bKFA00C1089
Remote-Party-ID: "Nedal Atiyyat" <sip:0785505500@192.168.230.2>;party=calling;screen=yes;privacy=off
From: "Nedal Atiyyat" <sip:0785505500@192.168.230.2>;tag=B0A55570-490
To: <sip:5555962788883597@212.118.26.3>
Date: Mon, 22 Jun 2015 09:46:31 GMT
Call-ID: 65626123-17FA11E5-AAF59701-121457CB@192.168.230.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3881509888-65536-1639187-531278016
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1434966391
Contact: <sip:0785505500@192.168.230.2:5060>
Call-Info: <sip:192.168.230.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 60
Allow-Events: telephone-event
Max-Forwards: 69
Content-Length: 0
102408: *Jun 22 12:46:31.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
From: "Nedal Atiyyat" <sip:0785505500@192.168.170.31>;tag=aeccc64a-4d9a-49ae-a58f-d89f9e1e529a-57073288
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
102410: *Jun 22 12:46:31.535: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Nedal Atiyyat"<sip:0785505500@192.168.230.2>;tag=B0A55570-490
CSeq: 101 INVITE
Content-Length: 0
102424: *Jun 22 12:46:45.059: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:5555962788883597@212.118.26.3>;tag=zvkxxz90-CC-23
CSeq: 101 INVITE
Contact: <sip:5555962788883597@212.118.26.3:5060;user=phone>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Content-Length: 327
Content-Type: application/sdp
v=0
o=HuaweiSoftX3000 153432369 153432369 IN IP4 212.118.26.3
s=Sip Call
c=IN IP4 212.118.26.7
t=0 0
m=audio 4044 RTP/AVP 8 0 18 4 2 97
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=fmtp:18 annexb=no
102425: *Jun 22 12:46:45.075: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:5555962788883597@172.31.21.3>;tag=B0A58A80-7C9
CSeq: 101 INVITE
Contact: <sip:5555962788883597@172.31.21.3:5060;transport=tcp>
Call-Info: <sip:172.31.21.3:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: sdp-anat
Content-Disposition: session;handling=required
Content-Length: 303
v=0
o=CiscoSystemsSIP-GW-UserAgent 7960 5475 IN IP4 172.31.21.3
s=SIP Call
c=IN IP4 172.31.21.3
t=0 0
m=audio 16434 RTP/AVP 0 18 101 19
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
Here the User is hearing ringing instead of the announcement, the 183 session progress is never Ack'd, or 200 Ok by neither way
MTP is checked on the Trunk , Could you please let me know what  could cause this issue
Much appreciated.
10 Replies 10
Vivek Batra
By the way at SIP level, this seems invalid SIP message flow. In case of delay offer (INVITE without SDP), SDP offer must be included in first reliable response which could be either 200 OK (for INVITE) or 180/183. If it's 180/183, it's mandatory to use 100rel/PRACK to justify the usage of reliable 183 Session Progress and PRACK must be sent with SDP answer.
Moreover there is no complete offer-answer done in this call flow hence I see very rare chance of media being relayed from service provider.
So either media (RBT) is being relayed from service provider or phone is playing locally. You can check show voip rtp connection to actually see if gateway is getting RTP packets from service provider by that time.
Vivek
Hello Vivek,
Thanks for your reply :) .
I have created a new SIP profile from CUCM 8.0.3 i have with the option to send a PRACK on 1xx Rel  SIP messages, still no progress on this at all, from the deubg ccsip messsages on the gateway i can see the following:
1) CUCM sends Gateway Invite as we are trying to make the call
2) GW sends CUCM trying and Sends provider an Invite.
3) Provider Sends Trying
4) Provider checkes that the phone is closed and sends GW 183 session progress with SDP to play the announciation.
5) Gateway Sends the same 183 to CUCM.
6) CUCM Sends PRACK to GW
7) GW Sends 200 OK to CUCM
Call now hangs, no announcement is heard, the ringing stopped and now facing the silence issue with the phone is closed after the change on the profile.
the Trunk have an announciatior in its MRGL, where should i continue troubleshooting on this one.
Gw level , or CUCM level ?
please check attached :
CUCM --- GW
Call-ID: 16353680-58f1f0aa-2adeed-1faaa8c0@192.168.170.31
GW --- PROVIDER
Call-ID: 90D7BDEA-1CE111E5-99E59701-121457CB@192.168.230.2
Regards.
Nash
Hi Nash,
Try checking the option " Early Offer support for voice and video calls (insert MTP if needed)" in the SIP Profile applied to the CUBE SIP Trunk and check please?
EDIT: you would need to enable 'early offer' on the dial-peers facing the ITSP as well.
//Suresh Please rate all the useful posts.
Hey Suresh,
I have already done that as well, but in CUCM 8.0.3 the options is as follows
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b06siprf.pdf
I have put the option to be CLEARMODE
do you have the command "voice-class sip early-offer forced" in dial-peer facing ITSP?
could you please attach the CUBE config?
Thanks for your answer,
I have tried the command on the dial-peer facing the provider and now have the problem when answer the call is dropped.
I can see that its a provider issue that they don't send SDP in the 200 ok of the response when using this command.
Debugs for the call and gateway configuration attached.
Seems again issue with SDP negotiation. As now gateway is sending INVITE with SDP with 100rel enabled, 180 Ringing response has 100rel required so gateway is responding with PRACK. At this point of time there is no issue and SDP negotiation has been completed.
Now 200 OK (of INVITE) received from service provider is without SDP. With PRACK used, there is no need to include SDP answer in 200 OK but somehow seems gateway is expecting to see SDP in 200 OK.
To prevent this, disable 100 rel on dial-peer pointing to service provider. Doing so, gateway will send INVITE with SDP offer and gateway will get SDP answer in 200 OK (and may be in 180/183).
Please check if this resolves your issue.
Sample configuration;
dial-peer voice 4013 voip
 translation-profile outgoing outgoing-Uminah-sip
 destination-pattern 555599627........
 voice-class codec 1
 session protocol sipv2
 session target ipv4:212.118.26.3
 voice-class sip rel1xx disable
 dtmf-relay sip-notify rtp-nte h245-signal h245-alphanumeric
 no vad
PS: You don't have any SIP bind commands in your configuration.
Vivek
As gateway is sending INVITE w/o SDP and received SDP offer in 1xx without PRACK being used on service provider side. This is not correct as per SDP offer-answer model. To avoid this and as mentioned by Suresh, use early offer on dial-peer facing service provider using command voice-class sip early-offer forced.
Vivek
ansonantoo
Try to enable PRACK on CUCM under service parameters.
Set ‘SIP Rel1XX Options’ to ‘Send PRACK if 1xx Contains SDP’
I have enabled that from the SIP profile but with no luck , the traces shows that the CUCM is sending the PRACK but gateway  don't
