Route Pattern Question?
james.ferris
Level 2
Level 2
I'm setting up a nurse call intergration between Rauland 5 Responde and CUCM.  In order to call the nurse call system from a cisco phone i need to dail:
Area*Room*Bed
For example to dial room 201 bed 1 I would dial:
201*201*1
The problem is that last number could be 1, 2 or 3 digits.
This is my current route pattern:
  [1-3]XX*[1-3]XX*!
it works just fine however using the ! makes me wait for the interdigit time out.
What would be the best way to write this patteren with out having to wait for the interdigit time out?
thanks,
James
Joseph Martini
[1-3]XX*[1-3]XX*!# would work, the users would have to know to dial the terminating # though.
Joseph Martini
Thanks!  I tried that earlier and was getting "call cannot be completed as dialed"  but i just realized i forgot to discard the trailing #!
Its working now.
has anyone of  you got the technical reference doc from rauland-borg about full integration with CM inlcluding ip service etc.
