IP Telephony and Phones
watch here Journey banner_1
Labels
Resolved! Locale Update 6921
Hi There,to upgrade a firmware, I put all files in the remote router's flash, set the TFTP in the phones to the local router so it's possible to upgrade..and it worked.. but in the log it does try to find the Portugal locale.. 004759: Nov  8 19:23:33...
Resolved! FAC code in CDR
Hi thereJust trying to get the FAC code to show in the CDR.We have set Clusterwide Parameter: "Display FAC in CDR" to true (didnt restart any service as manual says you dont neet to) but authorizationCodeValue filed in cdr still shows up with value "...
Not sure if I bricked this.  We used to use Asterisk so my 7960 phones and 1 7970 are flashed to SIP.  All works fine.  I tried to flash the 7970 back to SCCP but I think I screwed up the phone big time.  I wanted to flash them before I received my U...
HI AllIf i want to add New extension range on call Manager so should i only creat partition and CSS for that OR i have to add that extension range anywhere else.Example :We have existing extension range from 501 --> 599 and now i want to add new exte...
I have cisco CME V7.0 in Main office and it's using FXO to connect to PSTN, I have other PSTN lines in another building that i want to use as well.I have another CME with FXO readywhat I want is the following:I want to connect the main CME to other P...
saleh zwy by Level 1
  • 563 Views
  • 1 replies
Hi,I am facing issue with my CUCM (8.6.2) subscriber. The subscriber page is opening very slow. If i down the publisher then the subscriber web page is not opening it is showing 'loading please wait'. I have tried to restart the server but this didn'...
