Router 4321: isdn bind-l3 ccm-manager not included
I've tried to put the command isdn bind-l3 ccm-manager on the Interface Serial0/1/0:15 of an ISR 4321 but it's not included as an option, only q931. Does anybody knows how to solve this issue?
Cisco IOS XE Software, Version 03.15.01c.S - Standard Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(2)S1c, RELEASE SOFTWARE (fc1)
System image file is "bootflash:/isr4300-universalk9.03.15.01c.S.155-2.S1c-std.SPA.bi"
Building configuration...
Current configuration : 4426 bytes
! Last configuration change at 23:06:19 UTC Sat Jan 30 2016
version 15.5
no platform punt-keepalive disable-kernel-core
hostname #######
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
no aaa new-model
ip domain name ######.com
subscriber templating
isdn switch-type primary-qsig
crypto pki trustpoint TP-self-signed-3848114992
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3848114992
revocation-check none
rsakeypair TP-self-signed-3848114992
crypto pki certificate chain TP-self-signed-3848114992
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33383438 31313439 3932301E 170D3136 30313235 32323535
31365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38343831
31343939 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A0E8 6E808F9D 4F71E1D6 CA678CB1 ED50F967 33E86981 F3561527 8AAAB889
E0EE6BA9 0D0311D7 8B0B79F2 9EEA5251 EDFC32B1 BCD53AFE 082764D7 0AB5C8DB
D3EE3D8F 0FE15AB1 57213132 E99E4F15 02A78D18 7A172A5C 87CC8E39 D95CDBF1
BC8096B9 C9C15804 D44046A8 C084009D 34C89E8D 77D59935 22E79364 44E465C4
B57F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 140C7515 1B7FE340 BAEFD0A7 26E7796A CA207777 A4301D06
03551D0E 04160414 0C75151B 7FE340BA EFD0A726 E7796ACA 207777A4 300D0609
2A864886 F70D0101 05050003 81810031 82DC7E04 B32E27CF 9AD4BB21 0143D563
89BBBD06 62252E3E 897F2866 5FD3E852 692F1697 FF0F1B06 A0ED3CEF 271E0289
FF6B19C7 E6BC8263 A2083960 C99A9969 A569ACA2 8F45AE16 3B973F63 E4ADC418
A5A91094 72CFAFA0 6FC3ECD8 DB69ED46 93A2CEFF 811B2C33 7A6DE4F0 9975EB57
1B4B552B 44993C0A 304EBA2D CBAB4E
quit
cts logging verbose
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g729r8
voice-card 0/2
codec complexity high
no watchdog
license udi pid ISR4321/K9 sn FDO1938139S
redundancy
mode none
controller E1 0/1/0
pri-group timeslots 1-31
controller E1 0/1/1
vlan internal allocation policy ascending
ip tftp source-interface GigabitEthernet0
ip ssh version 2
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/1
ip address 172.18.49.1 255.255.255.0
no ip unreachables
no ip proxy-arp
negotiation auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Service-Engine0/2/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.18.49.254
control-plane
voice-port 0/2/0
ring frequency 50
no vad
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp
mgcp call-agent 172.28.16.10 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0/1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager mgcp
ccm-manager config server 172.28.16.10
ccm-manager config
line con 0
logging synchronous
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
logging synchronous
login local
transport input ssh
end
0 Replies 0
