Paging
Jawad Ahmad
Dears
I;m configure paing in our network, in paging group added 3 IP Phones. when press Speaker button and dial Paging DN, the Speaker on other phones showing active but no voice. can any one tell me whats problem.
Configuration is,
Ephone-dn 271
number 1111
name Sepco
paging
paging IP 239.0.1.20 port 2000
Ephone 1
Paging-dn 271 multicast
Ephone 2
Ephone 3
thankx.
Deepak Rawat
Have you tried unicast paging, does that work fine. If yes, then the issue probably seems to be with the multicast, try checking MOH as well if that works fine or not. What is the IOS & CME version you are running there??
I hope you are following the below guide that contains good information on how to configure paging with some troubleshooting information:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmepage.html
Deepak
Router IOS version
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.4(1)T4, RELEASE SOFTWARE (fc1)
CME Version
Version 10.0
