RTMT 8.7 - Configure email alert for successful backup
Hi folks--i'm having trouble finding the correct element to allow me to set an alert when the backup is successfully ran in CUCM 8.5/RTMT 8.7
All i can find is the CiscoDRFFailure element...Apparently it's somewhere, just not sure where.  I was under performance --> and went through all the menus to try and track it down...no luck.
any ideas?
Scott j.
Jing Hua
Hi Scott,
I am afraid that 'CiscoDRFFailure' is the only choice for DRF alert so far. However I believe we can use  DRF page > Disaster Recovery System -> Backup -> History  to check finished  DRFJob manually.
Cheers
Jing
Thanks for the info.
Hi Scott,
Not a problem.
Cheers
Jing
