03-12-2013 01:21 AM - edited 03-16-2019 04:12 PM
Tomcat Restart is not helping and the only drop in Memory usage is around 6% after restart i.e. i found that it is associated with Bug CSCsu53542 but not sure if the Call manager version 7.1.3.30000-1 is carrying a fix ?
03-12-2013 03:16 AM
The mentioned bug is fixed in 7.1.2.
Your version should not be affected.
26% isn't critical.
You could change the threshold in RTMT.
An other possibility is to reboot the server and test if there is more memory available.
Sent from Cisco Technical Support Android App
03-12-2013 03:33 AM
Thanks for the above post,
So you mean available memory less than 26% is not critical, so what could be the threshold we should set in RTMT ? We have a planned a weekly restart of the Tomcat service every friday to mitigate this. A reboot is not yet planned as we do not have the % of success ratio
03-12-2013 04:54 AM
I have seen CUCMs working fine with 90% swap / virtual memory usage.
Your version of 7.1 is old and may contain a memory leak. Maybe you search bug toolkit for something like this.
But CUCM 7.1 will soon be end of software maintenance anyway.
Regarding the reboot:
On the one hand you can schedule a reboot during a maintenance window and see if the memory consumption is lower.
On the other hand you can wait till you experience troubles during office hours.
