RTMT ISSUE !!!!!
MdSaifuddin
Hi All,
The RTMT is not able to connect to publisher while configuring the syslog.
but the subscribers syslog configuration is completed successfully.
Please help how to make RTMT to reach Publisher.
Attaching the screenshot.
As per the error pop up we dont have any dns configured in our cluster.
Kindly help me out.
Thanks.
SAIF
8 Replies 8
Aman Soi
Hi Saifuddin,
Just a thought : seeing the error message , can u try entering Publisher IP address followed by hdc3pub in Machine in LMHOSTS wehere RTMT is running?
it is located in windows \system32\drivers\etc\,
regds,
aman
Hi Aman,
Still facing the same issue after entering the Publisher IP.
Are u able to ping PUBlisher  from PC where RTMT is installed by using hostname [ping hdc3pub] ?
regds,
aman
Yes Aman i am able to reach the publisher.
Its working fine for subscribers.
Hi Saifuddin,
What is CUCM version u are using ? Is Publisher, Subscriber , PC on which RTMT is running and Syslog server placed at same site ?
was this working earlier or any change u did?
regds,
aman
Hi Aman,
>cucm v 8.5 .
>Its placed on same site.
>Its a new configuration,so didnt make any tweaks.
SAIF
Hi Saifuddin,
Not able to find the cause why it is not working.
If it is critical , then, u can open the case else wait  if anybody can help.
regds,
aman
Leo Laohoo
Duplicate post.
