RTMT message on low virtual memory
Ronit Malhotra
Recieving following RTMT alerts on presence server CM 8
Available virtual memory below configured threshold . Configured low threshold is 25 % tomcat (1065 MB) uses most of the memory.
Any suggestion?
9 Replies 9
m.batts
Level 4
Level 4
What exact version of 8 are you running?
Its 8.1
Hi Dheeraj,
Are the alerts being generated continuously or at some specific times of the day? This will help isolate if its happening due to some other process / activity on the server or not.
Have you tried restarting Tomcat or the CUPS server yet? Does the issue return after a restart ?
Can you check the output of the following command to see if there is any core dump on the server
utils core active list
Also , check for any issues by running 'utils diagnose test'
Please share the hardware specs of the server.
Manish
on Utils Diagnose test
I got following
test - disk_space          : Passed (available: 37124 MB, used: 4874 MB)
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : Passed
test - tomcat              : Passed
test - tomcat_deadlocks    : Passed
test - tomcat_keystore     : Passed
test - tomcat_connectors   : Passed
test - tomcat_threads      : Passed
test - tomcat_memory       : Passed
test - tomcat_sessions     : Failed - The following web applications have an unusually large number of active sessions: ==>query .  Please collect all of the Tomcat logs for root cause analysis: file get activelog tomcat/logs/*
test - validate_network    : Passed
test - raid                : Passed
test - system_info         : Passed (Collected system information in diagnostic log)
test - ntp_reachability    : Passed
test - ntp_clock_drift     : Passed
test - ntp_stratum         : Passed
skip - sdl_fragmentation   : This module must be run directly and off hours
skip - sdi_fragmentation   : This module must be run directly and off hours
test - ipv6_networking     : Passed
Diagnostics Completed
admin:utils core active list
      Size         Date            Core File Name
  73536 KB   2013-07-25 22:39:39   core.25987.11.ma.1374809924
  71152 KB   2013-07-25 22:40:02   core.24570.11.tc.1374809924
  78776 KB   2013-03-29 22:35:43   core.27693.11.cm.1364614496
I have not restarted tomcat service yet, do you think it should be restarted?
Dheeraj,
Does the start of the issue coincide with the core dumps generation date ( 25th July ). if yes, the core dumpbacktrace needs to be investigated. If the issue is recent then please restart Tomcat to start with and if the issue returns there needs to be further investigation by collecting Tomcat logs as suggested in the utils diagnose test output.
Manish
Hi Manish,
I am facing the same kind of error on my Call manager (Version running 10.5.2.12901-1)
Below are the error which I am receiving from RTMT & also find the below output of "utils core active list" & "utils diagnose test"
RTMT Error:
1. UsedDiskSpace : 92 MessageString : Common Disk utilization hits LWM!
2.   Available virtual memory below configured threshold . Configured low threshold is 30 % tomcat#1 (1858 MB) uses most of the memory.
Output from PUB CLI
admin:show status
Host Name : cucm01
Date : Mon Apr 24, 2017 12:55:06
Time Zone : Gulf Standard Time (Asia/Dubai)
Locale : en_US.UTF-8
Product Ver : 10.5.2.12901-1
Unified OS Version : 6.0.0.0-2
Uptime:
12:55:07 up 10 days, 21:22, 1 user, load average: 0.26, 0.42, 0.57
CPU Idle: 83.33% System: 07.29% User: 07.81%
IOWAIT: 01.04% IRQ: 00.00% Soft: 00.52%
Memory Total: 3925704K
Free: 113892K
Used: 3811812K
Cached: 387972K
Shared: 0K
Buffers: 51780K
Total Free Used
Disk/active 14643120K 1798244K 12696112K (88%)
Disk/inactive 14643056K 1896528K 12597764K (87%)
Disk/logging 50989088K 4112436K 44286476K (92%)
No core files found
admin:utils diagnose test
Log file: platform/log/diag4.log
Starting diagnostic test(s)
test - disk_space : Passed (available: 1757 MB, used: 12399 MB)
test - tomcat_sessions : Passed
skip - tomcat_heapdump : This module must be run directly and off hours
The final output will be in Log file: platform/log/diag4.log
Please use 'file view activelog platform/log/diag4.log' command to see the output
What should i do further to fix this issue ?
Vishal
islam.kamal
Level 10
Level 10
You might be hitting a bug that is caused due to high no of http requests to the Tomcat by RTMT.Goto RTMT -> Performoance Monitoring -> Tomcat web-application -> Active sessions -> ast.you will see the number of active sessions. Please find the number of sessions
You will gradually see that this value goes high due to memory leak. You can set the RTMT alert for this value as well.May be you hit  CSCtj50884. Might be useful in resolving this issue.Use also the below command :-
utils service restart Cisco Tomcat
I suspect that this is being caused by the common partition being full. Please attach the output of the following commands:
show status
show hardware
show version active
show process using-most memory
Thank you
please rate all useful information
I have following as active session
  • _root
  • ast
  • axl
  • CallRecordService
  • ccmadmin
  • ccmservice
  • CCMTrustCerts
  • ccmuser
  • CDRonDemandService
  • changecredential
  • cmplatform
  • controlcenterservice
  • cucreports
  • cupadmin
  • cupuser
  • dpservice
  • drf
  • emapp
  • EPASSoap
  • grt
  • Help
  • log4jinit
  • logcollectionservice
  • manager
  • perfmonservice
  • platform-services
  • plugins
  • realtimeservice
  • reporter-servlet
  • SNMPService
  • tomcatstats
  • tracecollection
  • TroubleshooterService
Show hardware
admin:show hardware
HW Platform       : 7825H4
Processors        : 1
Type              : Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
CPU Speed         : 3000
Memory            : 2048 MBytes
Object ID         : 1.3.6.1.4.1.9.1.583
OS Version        : UCOS 4.0.0.0-44
Serial Number     : MX29300086
RAID Version      :
1.86
BIOS Information  :
07/11/2009
RAID Details      :
Smart Array E200 in Slot 4
   Bus Interface: PCI
   Slot: 4
   Serial Number: PA6C90R9SXQ0U9
   Cache Serial Number: P9A3A0C9SXQ16W
   RAID 6 (ADG) Status: Disabled
   Controller Status: OK
   Chassis Slot:
   Hardware Revision: Rev A
   Firmware Version: 1.86
   Rebuild Priority: Medium
   Expand Priority: Medium
   Surface Scan Delay: 15 secs
   Post Prompt Timeout: 0 secs
   Cache Board Present: True
   Cache Status: OK
   Accelerator Ratio: 50% Read / 50% Write
   Drive Write Cache: Disabled
   Total Cache Size: 128 MB
   Battery Pack Count: 1
   Battery Status: OK
   SATA NCQ Supported: False
   Array: A
      Interface Type: SATA
      Unused Space: 0 MB
      Status: OK
      Logical Drive: 1
         Fault Tolerance: RAID 1
         Heads: 255
         Sectors Per Track: 32
         Cylinders: 59844
         Stripe Size: 128 KB
         Status: OK
         Array Accelerator: Enabled
         Unique Identifier: 600508B1001052395358513055390001
         Disk Name: /dev/cciss/c0d0
         Mount Points: /partB 42.1 GB, / 42.1 GB, /grub 258 MB, /common 146.5 GB
         Logical Drive Label: AF881CCEPA6C90R9SXQ0U96A8B
         Mirror Group 0:
            physicaldrive 1I:1:1 (port 1I:box 1:bay 1, SATA, 250 GB, OK)
         Mirror Group 1:
            physicaldrive 1I:1:2 (port 1I:box 1:bay 2, SATA, 250 GB, OK)
         Port: 1I
         Box: 1
         Bay: 1
         Status: OK
         Drive Type: Data Drive
         Firmware Revision: HPG8
         Serial Number: 9SF15C9Z
         Model: ATA     GB0250EAFJF
         SATA NCQ Capable: False
         PHY Count: 1
         PHY Transfer Rate: 1.5GBPS
         Port: 1I
         Box: 1
         Bay: 2
         Status: OK
         Firmware Revision: HPG7
         Serial Number: Z2AEQMSD
         Model: ATA     VB0250EAVER
         PHY Count: 1
admin:show version active
Active Master Version: 8.6.1.10000-34
Active Version Installed Software Options:
No Installed Software Options Found.
admin:show process using-most memory
MEM(K) PID  ARGS
108504 31987 /usr/local/cup/bin/syncAgent /usr/local/cup/bin/syncAgentJLauncherConfig.xml
138392 23355 /usr/local/cm/bin/cmoninit -w
191192 20690 /usr/local/cm/bin/RisDC
237128 321 /usr/local/pe/bin/pe
350416 759 /home/tomcat/tomcat /home/tomcat/tomcatJlauncherConfig.xml -Djava.library.path=/usr/local/sip/libexec:/usr/local/sip/modules:/usr/local/pe/lib:/usr/local/lib:/usr/local/thirdparty/java/j2sdk/jre/lib/i386:/usr/local/thirdparty/java/j2sdk/jre/lib/i386/server:/usr/lib/pgsql:/usr/lib:/usr/local/cm/lib::/usr/local/platform/lib:/usr/local/pe/tt/TimesTen/tt60/lib -XX:ErrorFile=/usr/local/thirdparty/jakarta-tomcat/logs/diagnostic-info.jvm-crash..tomcat.txt -XX:OnOutOfMemoryError=/home/tomcat/tomcat_diagnostics.sh -XX:OnError=/home/tomcat/tomcat_diagnostics.sh -Djavax.net.ssl.trustStore=/usr/local/platform/.security/tomcat/trust-certs/tomcat-trust.keystore -Djavax.net.ssl.trustStorePassword=DxDDqXEA1LrW8aTq -Djavax.net.ssl.trustStoreType=PKCS12 -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.logging.config.file=/usr/local/thirdparty/jakarta-tomcat/conf/logging.properties -Xmx640m -Xms256m -XX:MaxPermSize=256m -Djava.endorsed.dirs=/usr/local/thirdparty/jakarta-tomcat/endorsed -classpath :/usr/local/thirdparty/java/bcprov-jdk15-138.jar:/usr/local/platform/jar/xalan.jar:/usr/local/platform/jar/certMgmt.jar:/usr/local/platform/jar/certMonitor.jar:/usr/local/platform/jar/Iproduct.jar:/usr/local/platform/jar/Ihardware.jar:/usr/local/platform/jar/CiscoIPSec.jar:/usr/local/platform/jar/ciscoCmd.jar:/usr/local/platform/jar/ciscoCommon.jar:/usr/local/platform/jar/platform-api.jar:/usr/local/platform/jar/maverick-all.jar:/common/download:/usr/local/platform/application_locale/platform-api:/usr/local/platform/application_locale/cmplatform:/usr/local/cm/jar/commons-logging.jar:/usr/local/platform/jar/xstream-1.1.2.jar:/usr/local/cm/jar/log4j-1.2.8.jar:/usr/local/cm/application_locale/cmservices:/usr/local/cm/application_locale/car:/usr/local/cm/application_locale/ccmadmin:/usr/local/cm/application_locale/cupadmin:/usr/local/cm/application_locale/cupuser:/usr/local/cm/application_locale:/usr/local/thirdparty/jakarta-tomcat/bin/bootstrap.jar -Djava.security.manager -Djava.security.policy==/usr/local/thirdparty/jakarta-tomcat/conf/catalina.policy -Dcatalina.base=/usr/local/thirdparty/jakarta-tomcat -Dcatalina.home=/usr/local/thirdparty/jakarta-tomcat -Djava.io.tmpdir=/usr/local/thirdparty/jakarta-tomcat/temp start
Did you try the command  "utils service restart Cisco Tomcat"?. If yes , the problem is still running.
Thank you
