RTMT - Monitoring 2 CM clusters on one PC simultaneously
glenncarter
Does anybody know if there is a way to run two instances of RTMT on one PC to monitor two CM4.1(3) clusters simultaneously??
Cheers!
andibloch
Copy the program directory (JRtmt) and start it from the new copy.
gogasca
Level 10
Level 10
Yes use VMware
andibloch
Thanks ... you are a champion!
