RTMT not working after changing hostname on subscriber (unity connection)
latintrpt
Hello all,
Yesterday I moved my subscriber for Cisco Unity Connection to another data center.  I had it defined by hostname so I changed DNS to reflect the new IP.
Also changed the IP, name, and gateway under the OS administration.
The cluster was rebooted and replication is working just fine.
My only problem is that RTMT is reporting that the subscriber node "AMC service is down".  I have verified that the service is up on both the publisher and subscriber.  In RTMT the only node I'm seeing is the publisher.
Anyone have an idea as to what I'm doing wrong or missing?
I'm running version 7.1.3ES50.33039-50 on both nodes
15 Replies 15
Check this one (eventhough its fro CUCM same applies for CUC).
https://supportforums.cisco.com/docs/DOC-23535
Anand
Pls rate helpful posts!!
