05-25-2009 06:24 AM - edited 03-15-2019 06:10 PM
Hello
I have a little problem with our CM 4.1(3)sr8a, OS 2000.2.7 with Upgrade to 2000.4.5a and OS Service Release 2000.4.5bSR5.
I like to monitor the number of registered phones, cpu usage, memory usage etc. with the RTMT.
I don't know why, but it doesn't work anymore.
I get 0 registered phones, 100% memory usage etc. but this information can't be right.
Every idea is welcome. Thanks
Pascal
Solved! Go to Solution.
05-25-2009 06:38 AM
Hi Pascal,
When you upgraded to 4.1(3)sr8a did you install the "new" RTMT Plugin?
If any of the Client Plugins have a lower version than those included in this SR, perform the following:
After you have rebooted the server and completed the upgrade on all servers in the cluster, go to Cisco Unified CallManager Administration on any client machines (i.e. JTAPI, RTMT Client, etc.), navigate to the Application > Install Plugins menu. Choose the applicable plug-in, run the program from its current location, and follow the installation instructions that the system displays.
http://www.cisco.com/web/software/282074220/23393/ciscocm.4-1-3-sr8a-Readme.pdf
Hope this helps!
Rob
05-25-2009 06:38 AM
Hi Pascal,
Hope this helps!
Rob
05-28-2009 02:39 AM
Hi Rob
I did this installation of the new RTMT version and after a reboot of our CM yesterday, it works fine now.
Thanks for your help.
Pascal
