Run CUCM 7.1 as SUBS
Junior Mateus
Hi EveryBody,
I have a CCM Pub running on 7.1.5 and  i recently get second CCM already configured as SUBS but on version 7.1.3
I have 3 Questions :
1.Is it possible to built a cluster with the 2 CCM ?, knowing that it´s running on different version  ?
2.If the first question is yes,How can i erase all config on the CCM SUBS and add it to the cluster, knowing that it coming with database copy of a past PUB
3.Adding the SUBS to the Cluster require a additional License on  SUBS ?
Again thank you  in advance
Jaime Valencia
That's impossible, all servers in the cluster MUST run the same CUCM version.
You would need to install the other server as a SUB for the 7.1.5 PUB by reinstalling it with the 7.1.5 release, there's no way to just connect over to a PUB from another cluster, all the necessary agreements are done upon installation.
Yes, on that release you do need a node license.
java
if this helps, please rate
Jaime Valencia
java
Again Thank you for you response
Please do you know how can i upgrade the version 7.1.3 to 7.1.5 ?
Just get the upgrade image and run thru the upgrade wizard of CUCM.
java
