sAMAccountName Sync
Hi there !
I have created a new LDAP Directory to Sync with Microsoft AD.
It has Its own LDAP User Search Base (CN=_UnifiedC,OU=IPTelephony,DC=test,DC=com)
In the Microsoft AD, I have added a few users in that group.
What is the correct filter rule to select any user inside that Base ?
Should it work ? I’m trying, but it’s not...
(| (sAMAccountName=*)
Thanks.
Andrei.
Jaime Valencia
It's easier to define which users are synced from AD/LDAP by settting those permissions on the user you're using for the sync.
Just give read permissions over the users/OUs you want to sync
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
