Script Error when adding phone
r.lusignan
Hi, having some trouble figuring this one out. When a 7970 phone is added, all parameters are filled out. As soon as you hit the "insert" button I get the following error:
Error Information
https://ccmxxx/CCMAdmin/_RemoteScripts/rs_phone.asp?_method=updatePhone&_mtype=execute&pcount=68&p0=&p1=30018&p2=30006&p3=0&p4=SEP0015F9C85467&p5=SEP0015F9C85467&p6=&p7=&p8=%7B1B1B9EB6-7803-11D3-BDF0-00108302EAD1%7D&p9=&p10=%7BF0E328E8-DA95-4571-B3BB...
Anyone run into this before? This is only for the 7970 phone, everything else is ok.
Jaime Valencia
seems you're hitting:
CSCsg22098
Externally found severe defect: Resolved (R)
can't update phones in cm4.2(3) - urlscan reject maxquery string exceed
java
if this helps, please rate
Thank you, i'll check out that resolution!
Zin.Karzazi
Level 5
Level 5
you are hitting BUG CSCsg22098
