secondary dial tone delay
caseywyman
I have a site that is having issues with secondary dial tone. They press 6 to receive access to make outside calls. When they press 6, there is a secondary dial tone but if you wait 5 seconds you will hear a flash and then another secondary dial tone.
The problem is during the 5 seconds, they receive incoming calls on the line before they can dial out. Any suggestions would be appreciated.
This is a Cisco UC520 that has been setup through CLI.
I think you need to define specific patterns instead of T. Or at least can you try changing to 6.T.
-Terry
6 Replies 6
Terry Cheema
Could be due to overlap in the dial plan. Check your dial-peers for any pattern overlapping with pattern 6.
Do you have secondary-dialtone 6 under the telephony-service. Whats your interdigit timeout set to?
-Terry
Thanks for the reply.
I do have the secondary-dialtone 6 command under telephony-service.
I have two dial peers with a pattern beginning with 6:
destination-pattern 6T
destination-pattern 6911
The interdigit timeout is set to 3.
-Terry
Thank you I will give that a try.
I defined patterns for local, long distance,etc and it solved the problem. Thanks for the help.
Glad that solved your issue and thanks for the update.
-Terry
