07-29-2011 01:08 PM - last edited on 03-25-2019 08:08 PM by ciscomoderator
I have already installed a CTL Client and phones do not register with de CUCM while applying Security (security mode cipher).
Following steps are done:
- CUCM in Mixed Mode (Cluster Security Mode 1)
- Cisco CTL Client installed with two Tokens
- Reset CUCM
- Device Security Profile´s phone with a Secure Profile
What do you think would be the problem ?
Thanks in advance
Solved! Go to Solution.
07-30-2011 08:41 AM
Glad you found it yourself and shared, the last step in the CTL client tells you to restart CCM and TFTP on all nodes.
07-29-2011 04:25 PM
07-30-2011 08:41 AM
