Showing results forĀ
Search instead forĀ
Did you mean:Ā
Send Faxes to extension phone using RightFax server
mrmhar1408
Level 4
Level 4
We have the below scenario:
RightFax extension ---> Cisco Gateway ---> PSTN ---> Company greeting message  ---> dial fax extension ---> send fax
I want to know how we be able to send fax to fax extension in other companies
for example:
i want to send fax to 6906900 Ext 1500 from Rightfax, how to do that ?
cderrington
From within RightFax, you can create custom dial strings and/or complete dialing rules.
Your users can use the comma in the dial string to add pauses to an outbound fax call (ie 770-555-1212,,,,,,,1234#) te sever commas wil add a roughly 7 second pause then dial 1234 and the # to the call.
It is just a matter of trial and error to put in the correct number of one second pauses in the dial string.
Hope that helps,
Chad Derrington
Ingenium Software
Hi Guys,
Have you ever made this solution work? how do i need to write the destination-pattern and the forward digits?
I hope you can share the dial peer configuration with me.
Thank you for your support.
