IP Telephony and Phones
Labels
Is it possible to generate a message similar to "you have reached a non-working number" from within CUCM? We have a DN with corresponding DID and need CUCM to generate this message. I have tested and in a pinch we can just utilize the Telco-generated...
Cisco Unified CM ver8If a user doesn’t have a voicemail box and forwards unanswered/busy calls to another extension the call returns to the original extension if unanswered/busy but there is no voicemail box.How can I make the call terminate at the s...
hlewin by Beginner
  • 425 Views
  • 3 replies
Hi all,I'm new to the IT and Cisco phones environments so fairly unfamiliar.  I'm making this to see if a clients request is possible after looking around for a few hours with no clue if the search is in vain.We have Cisco  IP Phones 7945s.  We use C...
Emichalsen by Beginner
  • 1012 Views
  • 3 replies
We've been having intermittent MeetMe issues since we installed our system a year ago. We are using Call Manager 8.5 with the software MeetMe bridges. Max participants is set at 50. We only have 150 ppl in our entire company and the most concurrent m...
Hello Sirs,I have a 7911 phone that is nearly dead. I have used the sequence "power+#" then release "#" and then the sequence 123456789*0#.Then the phone boots up, request an IP from DHCP, then request 150, and then tries to download the "term11.defa...
mcecilia by Beginner
  • 279 Views
  • 1 replies
