01-24-2008 06:30 AM - edited 03-15-2019 08:24 AM
I've got an error with a SEP<MAC>.cnf.xml file, on the phone's status it says it can't validate the file and I was wondering if there was anyway of finding out which node it was complaining about?
Tim
01-24-2008 08:01 AM
Have you tried to download the phone configuration file manually to see if the file is actually present?
from win: tftp -i x.x.x.x get SEP
If you can download the file, I would suggest you examine by hand, it's XML and fairly human readable, ensure that nothing looks obviously corrupt.
Other ideas:
* did you load the onto the system via BAT? I have seen imported phones with essentially corrupted resulting TFTP files in certain cases.
* have you enabled security within your cluster? doesn't sound like it (you should get an "auth" error instead)
* is auto-registration enabled on the cluster?
If all else fails, you might try deleting and readding the phone manually via the web admin interface.
01-24-2008 08:10 AM
I hand edited it in the first place and have gone through it with a fine tooth comb, not sure which setting is wrong. Is there any documentation available for string lengths/values of each node? i.e. I found having the phone's label longer than 11chars meant it failed to load.
Tim
