Set B Channel ID information to Preferred in MGCP Gateway
Hi All,
We recently had some E1 PRI issues and our Service Provider has asked us to set B Channel ID information to Preferred.
We are using a MGCP Gateway with CUCM 9.1.2
When we enable ISDN debug we could see the Channel ID as Exclusive.
Jul 25 13:02:07.566: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0043
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
I tried to change it to Preferred by configuring the command, "isdn negotiate-bchan"   under the serial interface but still debug shows it as Exclusive only.
Let me know whether we can change the B Channel information either in CUCM or MGCP Gateway.
islam.kamal
Level 10
Level 10
Can you try the below:-
1- interface x/x/x:15
isdn protocol-emulate network
 isdn bchan-number-order ascending
then test again
2-Go to CUCM - gateway and do the below
CHANNEL IE TYPE " TIMESLOTS "
please rate all useful information
