Set up a help desk user to reset voicemail pins
mramirez-t
Is there a way to set up an admin user on the Unity servers (we have 2) so that the ONLY thing they can do is reset user's voicemail PINs and nothing else?
We're running 10.5.
Any help is appreciated.  Thanks.
Jaime Valencia
On your version you're limited to the canned roles you see, the ability to add custom roles was added in later releases.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/release/notes/b_Release_Notes_1151.html#id_18717
java
if this helps, please rate
