Setting a default background on the phones
David Rickard
I've had a dig around, and can't find any information, hence this post.
I've managed to set a new image for our 7911G phones. That all works fine, but unfortunately, the user has to go in and select that image, then save it. Is there a way - presumably by setting something in list.xml - to set our custom image as the default for a phone, so it will pick up that image unconditionally?
As I say, getting the image working wasn't a problem. As an aside, I'm a little bit perplexed as to how to go about putting an image on 7961 phones, as there doesn't seem to be any sort of space to fit one! From what I can see, it'll end up behind the text of the lines and caller info. I could be wrong though. Any advice gratefully received.
9 Replies 9
Jaime Valencia
unfortunately there is no way to set a default image, it's a manual per phone process
about the image on 7961's you're right. i set some background images on some test phones and since the lower part was black i was not able to see the status line, watch out for that
javalenc
java
if this helps, please rate
Thanks for the reply. Oh well, we'll just have to set the picture as we're setting them up.
A feature request, perhaps? ;-)
ive seen this request previously on TAC and also several times at the forum, perhaps if all of the guys looking for this could open a PER this could be included in a future release.
java
How does one go about opening a 'PER'? I'll gladly do so, although I don't think I have access to TAC, so I don't know if I need any sort of rights to do so.
You need to reach your Account Manager to see if you can open the PER, not all customers/partners can do it
javalenc
java
Ah OK, thought as much. I have a few HP consultants floating about - I bet they can!
Thanks for the help :)
mdury
Hi David,
would anyone be able to post some of their 79X1 background images. I am trying to get some ideas
Don't think there's much point me posting the image I used: I just used our standard logo (see it here: http://www.bucks.ac.uk/).
What I did do though, was I made sure to get a monochrome version. I also pushed it down to just two shades - black and white. The 7911G can only handle two 'colours', as it were. I resized it down to the size required (keeping the aspect ratio correct; I resized, down to the width, then made the canvas taller to fit). I then had to re-draw the smaller text, as it didn't size down properly. Anti-aliased, it looked fine, but in two colours, it lost the detail. So I just re-drew it in, and tidied up the rest so the roundel was round, and the other text fit properly. Little bit of fiddling, and it looked fine.
I did that using Paint and Paint.NET, so I didn't need any fancy tools either.
I am going to experiment with the 7961G by just putting a smallish logo in the bottom right corner. I have a feeling the text has a background, so the two won't clash, which would go against accessibility guidelines and whatnot.
Thanks David
