Setting up a modem lab
ayen
All-
I intend to setup a simple modem lab as follows:
To simulate the POTS phone lines, instead of using POTS line simulator like virtual console, can I use one 2811 router with VIC2-2FXS module, any configuration suggestions will be appreciated.  Thanks for your input.
acampbell
Alan,
Happy New Year.
All the best for 2013.
Yes, this should be OK.
I take it that your router has a DSP like
a PVDM2-8 to cater for the FXS ports.
2 FXS ports and dial peers.
voice-port 0/0/0
desc *** LEFT HAND MODEM ***
cptone
voice-port 0/0/1
desc *** RIGHT HAND MODEM ***
cptone
dial-peer voice 100 pots
desc *** TO LEFT HAND MODEM ***
destination-pattern 7321111111
port 0/0/0
dial-peer voice 101 pots
desc *** TO RIGHT HAND MODEM ***
destination-pattern 2122222222
port 0/0/1
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Alan,
Happy New Year.
voice-port 0/0/0
cptone
voice-port 0/0/1
cptone
port 0/0/0
port 0/0/1
Alex.
Thanks a million Alex! I will test this out, will let you know if run into issues.
ayenatt08
Hi Alex
Thanks, the configuration has been tested good without issues; was able to dial out local to remote modem based on the dial-peer configuration.
Here are the configuration and hardware used:
Cisco 2811 - 512/128
IOS image: c2800nm-adventerprisek9_ivs-mz.151-4.M5.bin
PVDM2-32 (should be in PVDM0 slot)
VIC2-2FXS on HWIC0
The configuration was pefect.
pstn#show run
Building configuration...
Current configuration : 1313 bytes
! Last configuration change at 22:23:24 UTC Wed Jan 9 2013
version 15.1
hostname pstn
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
redundancy
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
description *** LEFT HAND MODEM ***
voice-port 0/0/1
description *** RIGHT HAND MODEM ***
voice-port 0/1/0
voice-port 0/1/1
mgcp profile default
description *** TO LEFT HAND MODEM ***
port 0/0/0
description *** TO RIGHT HAND MODEM ***
port 0/0/1
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
Alan,
Great to hear it worked.
Can you mark this case as answered
Alex.
