Setting up FXS/DID to Unified Communications Manager 6.0
loyaltysource
I have UCM 6.0 and have added a 4-Port FXS/DID card to a 1760 Router running IOS 12.3(14)T4. I have 4 Analog Trunk lines running into the card that carry our 20 DID block.
I have successfully registered the FXS card with UCM, but when I place a call on those trunk lines, I receive a fast busy. I have also tried adding wink start signaling, but when I do the card is rejected in UCM.
We are running SCCP from the phones to UCM and MGCP from UCM to the router.
Can anyone tell me where I have gone wrong?
Thanks!
irisrios
Level 6
Level 6
In DID mode, a voice-enabled Cisco 1751 router or Cisco 1760 router can receive calls from a DID trunk and connect the caller to the appropriate extension. Outgoing calls are not allowed on DID voice ports. If an outgoing call is attempted, the caller will get a fast busy signal. Dial tone is not present on DID voice ports.
4-Port FXS/DID Voice Interface Card Support on the Cisco 1751 and Cisco 1760 Routers:
http://www.cisco.com/en/US/docs/routers/access/1700/1751/software/feature/guide/babygrnd.html
