Setting up LAB - Unified Communications
mlsc
Hello
I am looking for some advice on how to setup a lab that would allow me to get started on some of the features of unified communications. I am looking for CUCM, SME, Unity Connect, Presence and Jabber. If I were to purchase certain licenses, would I be able to download all the required software and get started. If so, what kind of licences do I need and what are the minimum amounts that i need to buy.  I want to start as small as possible for now and later add more licenses to the lab to expand its use.
Thanks in advance, Michael
Jaime Valencia
Reach out to a Cisco Partner or Cisco Distributor as they will be the ones that will be doing the purchase for you and can provide you with some assistance for the ordering.
java
if this helps, please rate
