IP Telephony and Phones
Labels
Hi, Please consider following configuration: dial-peer voice 1 voip incoming called-number . dial-peer voice 2 voip incoming called-number . session protocol sipv2 Looking into documentation I did not find anywhere dial-peer protocol to be used for...
Hi All, We have an Analog GSM Gateway currently connected to the Voice Gateway via FXO Port. Once we are calling the Number on the GSM Gateway which has a incoming configuration on the Voice Gateway to CUCM, caller ID/calling number is unknown. This ...
I have a 7975 IP Phone.I did a Soft Reset with 123456789*0# and it got stuck in upgrading.Then I did a Hard Reset with 3491672850*# and now I can see all the lights of the phone turning on and off just for once and then black screen for eternity. I'v...
Resolved! MOH Audio Source
We are running CUCM 11 and had uploaded a new Music On Hold Audio file (NewAudio).  We set the Music On Hold Audio Source 1,2,and 3 to point to this new file (NewAudio).  Everything worked fine.  Now we want to change it back to the SampleAudioSource...
dtom by Level 1
  • 1145 Views
  • 2 replies
HI: We have a problem with 3 cisco ip phones series 7940, for a reason we dont know they have become useless.. and the message on the screen is UNPROVISIONED, you please tell us how we can fix it. thank you  Miguel Morales Quinta Del Mar  619-560-...
qdelmar01 by Level 1
  • 936 Views
  • 4 replies
